22re battery intake swap
Old 04-23-2008, 09:26 PM
84 yota ex-cab's Avatar
What all do you need to do to swap the battery and intake? Will the wiring for the AFM reach if you pull it out of the harness?
Old 04-23-2008, 09:33 PM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
Here's a good thread on the subject....
https://www.yotatech.com/forums/f116...y-swap-111508/
Old 04-24-2008, 02:22 PM
4Crawler's Avatar
I did something similar in my '85:
http://www.4crawler.com/4x4/CheapTri...shtml#Phase-II
AFM wires need to be extended, at least in my case. I used a 9-pin Molex connector (I think 7 wires are used) from radio Shack and cut the wires near the AFM, put in a male and female connector on the ends (plug back in to test). Then make up an extension cable with matching male and female connectors and plug that in and the wiring is extended.
Doug4320
03-24-2018 10:11 PM
mskalmus
05-28-2017 07:51 AM
steve miller
10-10-2015 01:40 AM
Huntingtruckcletus
07-08-2015 05:26 PM
HRDC0R19
07-05-2015 06:43 PM
Quick Reply: 22re battery intake swap
