22R-E Problems
Old Feb 18, 2006 | 09:40 PM
phajej's Avatar
22R-E Problems
Need help!! My 86 4Runner won't accelerate past 45mph, struggles to get over tiny 2ft high hills, bad idle for the first ten to 15 minutes and very poor acceleration. Help me out with any suggestions guys, I've already changed the clutch. Thanks.
Old Feb 18, 2006 | 11:38 PM
pruney81's Avatar
Won't go past 45 mph if you're lucky it might be the fuel pump.
Old Feb 19, 2006 | 05:03 AM
regularguy412's Avatar
I had similar symptoms. Was the fuel pump for me. Check the fule filter, too, or you'll shred a new pump pretty quickly due to backpressure.
Mike
Old Feb 19, 2006 | 08:14 PM
phajej's Avatar
Will do guys...Thank you very much!!
Old Feb 20, 2006 | 04:11 PM
SoCal4Running's Avatar
Is the CEL on?
Old Feb 22, 2006 | 10:02 PM
linuxrunner's Avatar
Dang, 45mph and it can even climb hills... lucky. . I wish mine went that fast, i mean it might but with the shaking and tranny wine i am afraid any day the entire truck is going to grenade. j/k, these things should go a little faster than that. check the obvious things first, ie. plugs, wires, timing, the way i figure it if it is free why not take a look? and if it is cheep why not replace?
Also check 02 sensor, mine was bad and my truck had many of the same problems, bad warm up and no power.
Old Feb 23, 2006 | 09:48 AM
kyle_22r's Avatar
my '79 would take a couple of miles to hit 50mph when i first bought it. turned out to be the fuel filter, a $3 part that made all the difference in the world!
Old Feb 23, 2006 | 09:59 PM
Change your fuel filter. i just changed mine and it fixed all my problems, my CEL would come on and give me a code for my Mass Air Flow Sensor, so i changed that and nothing helped. so it turns out it was the fuel filter, my truck would hesitate, and loose ppwer so thats prolly what it is
cody
SubiKing
Aug 21, 2021 03:57 AM
theking11863
Mar 19, 2016 09:36 PM
Logz808
Jul 26, 2015 07:09 AM
Jonny246
Jul 24, 2015 12:37 PM
kyletbert
Jul 17, 2015 11:39 AM
