22R Dipstick tube Removal/Re Install
Old 11-29-2008, 02:10 PM
Phate's Avatar
Question 22R Dipstick tube Removal/Re Install
looking at my rebuilt engine i realized, it doesn't have a dipstick installed, so i added that to my list of stuff to bring over from the old engine my question is, how do i remove the dipstick tube, do i just vice grip and pull or do i have to pop the pan off and do something there.
Old 11-29-2008, 03:01 PM
DudeBud's Avatar
vice grips, be easy and twist it back, and forth to work it out.
Old 11-29-2008, 04:26 PM
drew303's Avatar
you can do the above, its just a pressure fit. or I think you can get to it from the underside and push it out with a punch or bolt...
probably won't go back in as snug as it came out so some RTV to seal it is a good idea. Mine didnt fit back in the same as it came out, machine shop took it out tho =/
Old 11-29-2008, 04:34 PM
Phate's Avatar
Got it out, was a little over zealous but it didn't flatten it out Just can see some bite marks from the vice , out of rtv so will have to go get some. next to install are the flywheel, clutch, pressure plate then in with the new
cars-guy
08-16-2020 06:59 AM
dumpster84
04-30-2016 06:03 AM
adammtb
07-27-2015 11:57 AM
colasurdo
07-18-2015 07:06 AM
colasurdo
07-17-2015 08:28 AM
Quick Reply: 22R Dipstick tube Removal/Re Install
