20R or 22R Clyinder head swap
Old 03-12-2010, 07:36 PM
808Yodi's Avatar
Question 20R or 22R Clyinder head swap
I've heard that using a 20R head on a 22re brings high compression ratios...
Anybody know the verdict on this and if it's worth doing for a new cylinder head job?
Old 03-12-2010, 08:34 PM
abecedarian's Avatar
In general, yeah, that's true... with early 22R/RE engines. 85 up engines are somewhat different enough to make converting to the 20R head a lot more involved.
http://www.toysport.com/Technical%20...tech_notes.htm
Old 03-13-2010, 11:11 AM
tried4x2signN's Avatar
Location: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
Real time: Lets talk about the 20/22R Hybrid!
Using a 20R Head on an 85-95 22RE Block
I don't recommend that... Might work, who knows. But the compression has to be reduced b/c high top pistons are no longer being used... Then what's the point?
I've heard a cam and header open it up even more...
Old 03-13-2010, 11:13 AM
It's worth doing if you have a 22R and want to bump up the power.
It's the alternative to a head achey EFI transplant and and other stuff like a Turbo.
It's easy, fast and cheap. You also get double row chains and steel guides
1 stop shop...
sandyota
02-04-2021 11:16 AM
cars-guy
07-11-2015 07:51 PM
Tyler Cunningham
07-11-2015 10:18 AM
Coreyr384
07-10-2015 11:13 AM
87blyota
07-10-2015 04:31 AM
Quick Reply: 20R or 22R Clyinder head swap
