1994 3.0 water pump /timing belt
Old 03-21-2016, 05:51 PM
Jonny246's Avatar
I need some info on a timing/water pump kit. I have checked all parts stores in my area and all they sell with em is a junk Duralast or similar water pump Its was highly recommended to purchase a kit with a Aisin Water pump . It seems I can only purchase this online, who is a trusted co to purchase this from. Also it seems all kits do not include a Hydraulic Tensioner or a adjuster its that true for all kits it must be purchased separately? I am NOT doing the job I will not screw around with some I know nothing about I just don't want to either order the wrong parts or junk Thanks for any advice
Old 03-21-2016, 06:09 PM
MudHippy's Avatar
Rockauto.com
AISIN TKT014
Old 03-22-2016, 01:31 PM
Crazychris1871's Avatar
Everything you need cheap.
There is a great seller on eBay called The Parts Wizard that has all the parts in a kit for less than $100.
http://m.ebay.com/itm/Timing-Belt-Kit-Water-Pump-Valve-Cover-Fits-88-92-Toyota-Pickup-3-0L-SOHC-3VZE-/251505892042?nav=SEARCH
Old 03-22-2016, 01:55 PM
MudHippy's Avatar
Is price the issue here?
I think not.
Quality. OEM quality. AISIN in particular.
So which reputable manufacturer made those parts?
There's a reason they're so cheap, and why it's not stated which brand they are.
I wouldn't buy from that guy in a million years...at any price. Not to mention the kit you provided the link to is for the wrong year.
Old 03-22-2016, 02:35 PM
I think not.
No need to be condescending, this is a friendly forum.
As far as the wrong year goes, yes that was a simple mistake, which I made. I'll own up to it. This is actually the link.
http://m.ebay.com/itm/Timing-Belt-Kit-Water-Pump-Valve-Cover-Fits-93-95-Toyota-3-0L-V6-SOHC-3VZE-/251627367419?nav=SEARCH
As for the brand of parts, they are made by DNJ Engine components, and when I put this same kit on I had and have had zero problems with it. Simply because a part isn't OE doesn't mean it's garbage.
buckz6319
12
03-26-2016 07:39 AM
Sporkinator
03-18-2016 06:08 PM
808-3VZE
03-16-2016 05:09 PM
yotes86
03-15-2016 08:17 AM
deez_king
03-03-2016 06:02 PM
Quick Reply: 1994 3.0 water pump /timing belt
