1992 22RE Will Not Start When Warmed-Up
I have a 1992 Toyota Pickup with a 22RE engine and the truck would not start when warmed-up. I have read many threads regarding this issue but nothing worked. After much frustrations, just by chance, I noticed that the battery was 8 years old. I replaced the battery and it made all the difference. The truck not only started with gusto every time, the truck ran a lot better. If you every encounter this problem with your truck, and it runs fine except for warm start-ups, try replacing your battery. I hope this helps.
You might want to check your static fuel pressure, AND pressure leakdown time.
If you have leaking injectors, or a ruptured FPR bladder (which will allow fuel into the vac supply line), you'll get more fuel in the cylinders than is needed. Fine for COLD starts, but HOT restarts will be hard.
Define "Start"
Crank as in starter turning the engine?
Combustion as in VROOM?
Start: engine turns over (cranks) normally but the engine does not run by itself. Warmed-up: normal operating temperature.
Actually, adding more fuel pressure for HOT starts is exactly what the FPU (Fuel pressure-up) system does. It's purpose is to address vapor lock.
If the FPR regulator diaphragm ruptured, wouldn't you be pumping fuel directly into the intake manifold whenever the pump was on? While the pressure to the injectors would be too low, fuel pumped directly into the manifold should flood out the engine, hot or cold. (Could you be thinking of a leaking vacuum line to the FPR? That would result in higher rail pressure, more fuel, run rich.)
But this would be in fuel injected system, not carb'ed. I had that part wrong...
I bet carb'ed systems have a similar function.............................
What did you think was the purpose of the FPU? http://personal.utulsa.edu/~nathan-b...ne/99fuelp.pdf
I don't make this stuff up.
