1990 4Runner No Compression V6
Old 08-22-2009, 04:37 PM
megamc's Avatar
Lost all compression to all cylinders. Found timing belt intact but with the crankshaft timing mark at TDC, the camshaft marks are off at about 10 oclock. The distributor rotor is also off. If I line up the camshaft marks at 12 oclock, the distributor rotor is aligned at #1 but the crankshaft is off about 1/4 turn. So like what slipped and how do I correct and prevent it from happening again?
Old 08-22-2009, 05:00 PM
totally a bro
Staff
vital22re's Avatar
replace the timing belt, water pump, cam crank seals, tensioner and tensioner pulley and idler pulleys and line up the cam and crank when you replace the belt.
Old 08-22-2009, 06:47 PM
megamc's Avatar
So what slipped?
Old 08-22-2009, 07:02 PM
totally a bro
Staff
vital22re's Avatar
worn timing belt and or tensioner.
Old 08-22-2009, 08:37 PM
OutlawMike's Avatar
Yup, the timing belt went slip, slip, slipping away. And not just one or two teeth, but a whole bunch. Lucky for you it is not an interference motor, nothing damaged, just need to do the belt and all the other stuff mentioned above.
Have fun.
Old 08-23-2009, 06:53 AM
tc
tc's Avatar
If you don't know when the water pump was done last, should do it while you're in there.
Old 08-23-2009, 11:48 AM
eric-the-red's Avatar
I had the same problem on a 93 4Runner years ago, and I found this when I took the crank pulley off. Probably caused by someone not torquing the crank bolt correctly after a previous timing belt job.
Sleaker
08-26-2020 06:03 AM
MMA_Alex
25
04-18-2017 05:07 AM
thefishguy77
07-30-2015 10:59 AM
madxman21
07-09-2015 10:26 AM
ptb12
07-05-2015 01:49 PM
Quick Reply: 1990 4Runner No Compression V6
