1990 22re pickup 2wd problem
Old 11-21-2013, 08:55 PM
lomaxxx1337's Avatar
Cool 1990 22re pickup 2wd problem
I have a an old 1990 toyota 2wd pickup 22re without Anti Lock Brakes. My yota runs great. I do have one issue though, when I am pressing the brake to stop my engine revs itself, almost like it bogs down and then corrects itself. Like "vvvvv .... vvvvv.... vvvv...vvvv.....vvvvv" if that description makes any sense.
Also, on a different subject, I just started hearing a noise coming from what sounds to be one of the pulleys on the belt system. To describe that noise it sounds like sand in the bearings. What is the best way to troubleshoot which pulley it is? Over all the engine is noisy and it is hard to tell which one it is.
Thanks!!!!!!!!!
Old 11-22-2013, 10:44 AM
osv
osv's Avatar
I wonder if the brake booster has a vacuum leak in it?
Old 11-22-2013, 12:07 PM
SoCal4Running's Avatar
Engine surging when brakes applied is usually from too high a idle rpm.
Could be simply mis adjusted or vacuum leak.
How many can belts are on the truck? Could remove one at a time to see which accessory is the fault.
Old 11-23-2013, 11:43 PM
It was the tensioner pulley. Couldn't find a correct replacement for whole pulley at auto stores so I removed the bearing inside that was seized up and replaced with a new one, perfect fit! Got new belts and good to go!
Thanks.
Old 11-23-2013, 11:45 PM
Good idea. Ill have to look at a service manual to check!
Thanks
Also my rear brakes have never worked, I need to take to a shop or something because I have no idea where to begin on that issue!!!
bradstyle
06-19-2018 03:15 AM
bigblue82
10
07-06-2015 08:27 AM
GorgeRunner
06-27-2015 07:01 AM
Old Red 94
06-16-2015 08:32 PM
Fred Anarat
12
08-27-2002 04:50 PM
Quick Reply: 1990 22re pickup 2wd problem
