1989 Pickup Cluth/transmission issues?
Old 09-14-2015, 11:54 AM
Ott47's Avatar
I could not find anything to help myself by searching but I just had this strange problem with my toy. I was going to work today and while I have no issues getting it into gear, when you try to accelerate the RPM's will rise and the truck would slowly get to a top speed of about 40 mph. I stopped at a stop sign and then the RPM's would just raise but no movement from the truck. I am trying to figure out if this would be a clutch or a transmission issue? any advice would be helpful, you could also smell something burning, but strangely to me it smelled more electrical than anything.
Old 09-14-2015, 12:01 PM
millball's Avatar
Time for a new clutch.
Old 09-14-2015, 12:02 PM
Ott47's Avatar
should I even try to replace the slave/master cylinder or just go straight for the clutch?
Old 09-14-2015, 12:08 PM
millball's Avatar
There is no common failure mode of the clutch master, or slave cylinders that account for severe clutch slippage.
As an adjunct to clutch replacement, you may well replace the hydraulic cylinders if they are well used, or show any leakage.
Have you got oil leakage that might be attributable to a rear main seal leak or tranny input seal leak??
Clutches hate oil.
Old 09-14-2015, 12:09 PM
Ott47's Avatar
HA, as a matter of fact I do have a leak that could be contributed to a rear main seal
bigjstang
08-25-2021 12:41 AM
Regency
20
01-03-2020 07:43 PM
mskalmus
05-28-2017 07:51 AM
God's Bounty Hunter
07-08-2015 12:54 PM
Nickdigg
07-07-2015 06:04 AM
Quick Reply: 1989 Pickup Cluth/transmission issues?
