1989 22re Throws code 24 runs for about a minute then tries to idle then dies
Old 01-22-2013, 06:22 PM
rydholm11211's Avatar
I have a 1986 toyota truck that that had a complete 1989 engine swap with ECU and harness, well I just bought this truck and the When I start it it will runs good for about a minute and then tries to idle and will die, and I checked the code and it is throwing 24. The fuel pump is coming on, I can drive it at higher RPS and it will run descent but hesitates some times, Im thinking that there is a bad connection between the Mass air flow meter and the ECU? Could that be my problem?
Old 01-22-2013, 06:36 PM
warpigg's Avatar
its sounds like you thought, something with the maf. what is code 24 btw?
06-01-2021 01:51 PM
toyota32
07-06-2015 05:42 PM
Jnkml
07-06-2015 01:20 PM
CJ94yota
07-03-2015 10:14 PM
94 bikehauler
06-30-2015 11:19 PM
Quick Reply: 1989 22re Throws code 24 runs for about a minute then tries to idle then dies
