1988-92 3vz-e timing belt install
Old 07-17-2012, 04:24 AM
kuzbro's Avatar
Part of the install instructions for the 88-92 3VZ-E tells you to remove the camshaft sprocket bolts and dowel pins to allow the sprockets to turn freely. I have the following questions:
  • What is the best way to hold the sprockets to remove the bolts?
  • Are there any concerns with the dowel pin removal and reinstall?
  • Is there a method/rule of thumb in knowing the belt on the none tensioner side is properly "taut" between the sprockets?
At this point I am wondering why the sprockets have to come off, however I have learned the hardway to not second guess the FSM. Anyway, I'd appreciate any advice, experience, comments.
Old 07-17-2012, 04:48 AM
TNRabbit's Avatar
I know of no need to remove the sprockets. You'll want to start with getting the tension between the crank & driver side cam pulley correct. Then, cock the passenger side can sprocket SLIGHTLY to the right (@ half a tooth) before you put the belt on, & that will take up the slack. Lastly, you want all the slack to be taken up by the tensioner between the passenger side cam & crank.
Old 07-17-2012, 05:12 AM
Greenhornet4nr's Avatar
I agree with TNrabbit. No need to remove sprocket to do the timing belt. Unless your doing the idler pulley too. If you are then I recommend you use sprocket holder tool. A spanner wrench will do the trick too. But they make a holder specifically for Toyota sprockets. You could even try a chain wrench. But you risk damaging the teeth on the sprocket.
Old 07-17-2012, 05:33 AM
TNRabbit's Avatar
You csan also make a sprocket holder out of the old belt & a piece of angle iron, but that's not ideal....
Old 07-17-2012, 06:27 AM
Marc's Avatar
Here's a link to a writeup for a crank bolt removal/installing tool.
https://www.yotatech.com/forums/f116...l-tool-186081/
Old 07-17-2012, 09:00 AM
Fraser's Avatar
I have never removed the cam sprockets while changing the t-belt. It would make access to the water inlet pipe bolts a little easier, but you can get at those with a decent wobble setup without too much trouble.
Old 07-17-2012, 08:41 PM
kuzbro's Avatar
TNRabbit's install instructions worked great. Thanks for all advice/tips/help. I used a 1/4 drive socket (short one) and wobbly-joint to install the #2 idler. I'll keep you posted. Thanks for quick response.
bigjstang
08-25-2021 12:41 AM
coryc85
09-09-2015 06:24 AM
colinmil
07-06-2015 04:03 PM
zd92655
07-05-2015 04:25 PM
Quick Reply: 1988-92 3vz-e timing belt install
