1986 Toyota 4Runner SR5
Old 03-07-2007, 07:05 PM
weaselman's Avatar
I have a few questions on some stuff, and hopefully some one can point me in the right direction..click images to enlarge
You guyz have answered most of my questions here, but i still have one left..
I was also wondering if anyone had this middle dash piece that they are willing to sell or give away
http://img.photobucket.com/albums/v3...k/DSC00182.jpg
Old 03-08-2007, 05:27 AM
weaselman's Avatar
btt...anyone??
Old 03-08-2007, 05:07 PM
weaselman's Avatar
ttt...anybody? at all? a link or anything would be helpfuL
Old 03-08-2007, 05:14 PM
runner4thebeat's Avatar
Originally Posted by weaselman
i was also wondering if anyone had this middle dash piece that they are willing to sell or give away
they have these on ebay for fairly cheap but you can probably find it cheaper at junkyards
http://cgi.ebay.com/ebaymotors/1984-...91676181QQrdZ1
Old 03-08-2007, 05:19 PM
fthertime666's Avatar
wow, someone screwed that rig up!
first pic is missing fuel pressure return line.
dunno about second, but tracing that tubing to its other end would prolly help
give you an idea.
the other two, I think, are for the AC which it loks like someone ripped out.
Old 03-08-2007, 05:21 PM
SoCal4Running's Avatar
Lets see in order,
#1 - that is your fuel pressure regulator and has a hose that goes from it to the rear VSV on the back of your valve cover. Scratch above that is your return line....WOOPS
#2-Will have to look on my 4runner, dont know off top of my head.
#3- No
#5-?????
Old 03-08-2007, 05:47 PM
Old 03-08-2007, 05:59 PM
Bill's Avatar
I'm not exactly sure what part the plug in the last pic is for, but I think I know where it goes.
If you look uned the intake runners, at the front, just behing the bottem of the TB. There is an injector style plug in the faces the firewall.
It could also be the plug in for the cold start injector. Look on the driverside middle of the Plenum, right in the middle there is a banjo fitting. There should be an injector style connector hooked up about 1/2" away.
Old 03-08-2007, 06:01 PM
weaselman's Avatar
what is this cap for?
http://img.photobucket.com/albums/v3...k/DSC00210.jpg
is this the hole for the oil pressure?
http://img.photobucket.com/albums/v3...k/DSC00209.jpg
whats this for?
http://img.photobucket.com/albums/v3...k/DSC00207.jpg
Old 03-08-2007, 06:02 PM
weaselman's Avatar
yea, i found out where that plug thing goes...thanx
whats this for?
Old 03-08-2007, 06:09 PM
Drama Queen/Banned
paxil4x4's Avatar
That hole in the side of the head is where a fuel pump goes on a 22R. Looks lke somone cobbled the motor together with a 22RE
Old 03-08-2007, 06:13 PM
weaselman's Avatar
so i could just cap that hole off in the head? just make a plate and screw it on?
Old 03-08-2007, 06:15 PM
4runnerx3's Avatar
the cap/boot is the oil pressure sending unit hook up. There is a clip that slides over the end of the unit, then you slide the boot on. You can get the sending unit at NAPA for $37. The hole under the oil filter is where the oil pressure sending unit goes. When you get a sending unit, get one for a gauge, not an idiot light.
Old 03-08-2007, 06:17 PM
linuxrunner's Avatar
The first and second pic look like the dashpot off of the side of the intake must have put the screw to slow down throttle from closeing as air cannot escape as fast.
Old 03-08-2007, 06:18 PM
4runnerx3's Avatar
The VTV is supposed to have a little filter on the end, not a screw.
Old 03-08-2007, 06:19 PM
weaselman's Avatar
sweet, thanx for the help...almost all of my questions have been answered...woo!
correct me if i am wrong, but a manual gauge could go there correct? (in the side of block where sending unit should be)
Old 03-08-2007, 06:21 PM
4runnerx3's Avatar
Do you have an SR5 cluster?
Old 03-08-2007, 06:23 PM
weaselman's Avatar
as far as i kno, yes...as far as i kno its stock, so it must be an sr5 cluster
Old 03-08-2007, 06:24 PM
4runnerx3's Avatar
Does the cluter have an oil pressure gauge (left side) or an idiot light?
Old 03-08-2007, 06:25 PM
weaselman's Avatar
it has the gauge, no idiot light for me...
Quick Reply: 1986 Toyota 4Runner SR5
