tps adjustment
tps adjustment
i bought my 4 runner a while ago and the tps seems so be off. What is the ohms supposed to be set at?Any tips? its a 85 22re
You never know... you're throttle shaft bushings might be sitting on a door linkage setup for some other make and model car.
I figured I'd just bump this thread instead of making a new one. Anyway Ive been trying to adjust my TPS and I can't get the second setting correct as per 4Crawlers diagram. 1, 3, 4 and 5 come up correct. Does this mean its time for a new TPS? How far out of spec is ok if at all? I get an open infinite reading on the .57mm (actually .58 since I don't have the .57 feeler) setting as well as the .85mm setting. I don't wanna mess with it too much more since it is very close to being correct.
zytra
01-24-2019 03:16 PM
