Sr5 Cluster Swap
Sr5 Cluster Swap
I just picked up a cluster from a v6 1st generation 4runner. My question is about the oil pressure sender. Do I need to get an oil pressure sender from a v6 or from a 4cyl. Also, I read the tachometer may be off a bit. Can I fix this?
No, the sending unit doesn`t need to be from a V6, just get one for a SR5 22RE, but if you put the new cluster in before you change the oil sending unit unplug the sending unit on your engine first, otherwise you will fry the oil presure gauge. The tachometer will be off a little, and i know it can be corrected, but im not sure how to do it, try doing a search because i know its been posted here before how to do it.
Flying91
45
04-11-2024 04:39 PM
Esibnitsud
07-30-2015 08:21 PM
