YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 84-85 Trucks & 4Runners
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 08-26-2008, 05:37 AM   #1 (permalink)
Spring Shackle Bolt HELP!!!!
I am having a hell of a time getting the from spring shackle bolt out on my 88 4Runner. I got the right spring removed already and the left is ready to come out but I CANNOT get the front bolt to come out.
I have hammered on it, impact gun, breaker bar, i can feel it snap with the breaker bar. It feels spongy and then it snaps once each time i put the breaker bar to it. But the son of a bitch won't come out!!! I need this thing out today so I can go and get my springs re-arched and an extra leaf added.
HELP!!!!!
p.s. the nut is off the bolt, the bolt just won't come out of its hole. The bolt is turning though
__________________
88 4Runner
85 VW Scirocco
4RunnerFreedom is offline
Sponsored Links
To remove this ad, register today!
Old 08-26-2008, 06:32 AM   #2 (permalink)
20twinz's Avatar
Spray it down with some PB Blaster and let it sit a while or if you have new bushings you could try and heat it up as well....
__________________
My Mind Never Stops!
20twinz is offline
Old 08-26-2008, 06:52 AM   #3 (permalink)
dirtoyboy's Avatar
I would cut it out...
ues a sawzall, grinder or hacksaw
if you have power tools its a 30 second job
__________________
Low down and durrrrrrrty Rock stacking Web Wheeler.
Locked, lifted, trussed, SASsed, triangulated, dual cased, shaved, armored, gusseted, hydro'd, blacked out, crapped out, mashed up, merderrrrrd out and ready to hit the mall!
It's a Jaap thing....You wouldnt understand
Quote:
Originally Posted by SwampThing View Post
Oh, after a consult with Mr. Anheuser, I think I beer-stormed a way to test the gears
dirtoyboy is offline
Old 08-26-2008, 07:54 AM   #4 (permalink)
looks like a specialty bolt though. i don't want to wait 2-3 days for the dealer to order one in
__________________
88 4Runner
85 VW Scirocco
Old 08-26-2008, 07:59 AM   #5 (permalink)
dirtoyboy's Avatar
Quote:
Then torch it out (the bushing) and then u can (maybe) reuse the bolt...
I can tell ya that er is seized to the rubber on the bushing....banging on it with a hammer/impact/whatever wont do a thing
__________________
Old 08-26-2008, 08:19 AM   #6 (permalink)
had the same problem, and PB blaster and patients is the best policy. So I cut mine out, but later I realized the soaking and waiting can be a little faster than ordering parts.
__________________
Tom H
Mt Vernon, MO
chief designer of the oxy-moron (head moron reporting)
http://www.yotatech.com/f151/project-oxy-moron-151018/
trbizwiz is offline
Old 08-26-2008, 08:25 AM   #7 (permalink)
drguitarum2005's Avatar
Location: Houston (home), Atlanta (school), Cincinnati (work)
Send a message via AIM to drguitarum2005
i had to cut mine out when the bolt stripped on me. im sure its not a specialty bolt, try your local home depot, lowes, ace hardware, whatever
__________________
-David
2000 Taco TRD Access Cab
v6 | 5spd | 33" BFG A/Ts | 33" PC Mud Terrains | OME 882's | Bilstein HD struts front | Rancho shocks rear | Chevy 63" leaf spring swap | Custom sliders | Custom front bumper |3" BL | U-Bolt flip | Flowmaster exhaust | Kenwood Speakers | Grey Wire Mod | Aux. Reverse Lights | Deckplate Mod | Lots of lights
Pictures
drguitarum2005 is offline
Old 08-26-2008, 09:01 AM   #8 (permalink)
4Crawler's Avatar
What is probably going on is that the shackle pin has rusted inside to the bushing. That is there is a big lump or rust+rubber on the pin in the center of the bushing. What I found that worked on my '85 was to sit the spring on it's side and soak with penetrating oil (petroleum-base to soften the rubber) and then twist the shackle and let it sit for a while then repeat. Took about a half a day to soak enough oil in there to soften the rubber enough to allow the enlarged section of the pin to come out of the bushing, which happened when twisting the shackle and using a pry bar underneath to lever it up. The stock shackle pins are not easily replaced, so it you do have to cut it, plan on buying new shackles. Maybe the spring shop can press the pin out.
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs.
r.c.brown@ieee.org
TruckEditor@tlca.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 08-26-2008, 09:18 AM   #9 (permalink)
dirtoyboy's Avatar
Quote:
well they are somewhat of a specialty bolt.....your entire truck is riding on that bolt.......if it fails...so does your truck...
It does need to be the correct grade and size...no questions
__________________
Old 08-26-2008, 09:25 AM   #10 (permalink)
4Crawler's Avatar
It is not really a bolt, per se. It has a flat round head that is pressed/welded into the shackle side plate and then has a stepped down shoulder (from 18mm to 14mm diameter) with the threaded portion. Not going to find something like that even at a specialty fastener shop. I doubt even Toyota would see you just that pin, probably need to buy a new shackle or modify the shackle plates to take a regular bolt.
__________________
r.c.brown@ieee.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 08-26-2008, 09:45 AM   #11 (permalink)
BLKNBLU's Avatar
Quote:
I think he might be talking about the front hanger bolt frome his descriptio of "front bolt". How about the old c-clamp and deep socket to press it out trick? Definately lets get clear on what we're working on here.
__________________
86 Runner, BFG 31's, custom Sonoran Steel rear bumper, 4Crawler 1" body lift, rock sliders from Richard Stubbs, Downey 3" lift rear leaf springs, SDORI ball joint spacers, rear Lockright
BLKNBLU is offline
Old 08-26-2008, 10:00 AM   #12 (permalink)
4Crawler's Avatar
I have some tips on removing the spring hanger bolt (if that is what is being referred to) below (see the 4th Q&A):
http://www.4crawler.com/4x4/TLCA_Tru...ech.04.01.html
__________________
r.c.brown@ieee.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 08-26-2008, 10:01 AM   #13 (permalink)
jmazoso's Avatar
I just did mine and had the sme problem. I cut the old shakle plate, and the top bolt came right out. The bottom wouldn't budge. I put a big pair of channel locs on the end of the bolt and twisted it around. A ton of rut and crap came out, then I was able to get it to come out.
__________________
Trail Truck: 84 regular cab 85 22r -- streetRV head, 261C cam, 2.5" flowmaster, lock-right in rear, 1" Wabfab BL, IFS brakes, rock sliders, diff breathers, Amsoil, dual cases, front rock lights, tube bumper, 33x12.50 BFG MTs, 213k miles
---Currently: 5.29 prescion gears, cryo'd (just need to get them installed) send money
---Next: Front bumper
Link to build-up: http://www.yotatech.com/f115/jmazoso...uildup-137611/
DD: 01 Tundra V8, 3" flowmaster, FIPK, 120K miles
jmazoso is offline
Old 08-26-2008, 11:14 AM   #14 (permalink)
isaac338's Avatar
if it's the spring hanger bolt it's easy to get out. grind both ends of it down till they're flush with the hanger on the frame, and then drive a claw hammer in between the spring and the hanger (to spread it out). you'll see the ground ends of the bolt pull into the hanger and you can force them in and down. took me about 15 minutes to do both sides.
once i cut the old bushing out i measured the bolt and went and bought grade 10 replacements. new poly bushings and you're golden.
__________________
1994 Xtracab pickup, 180,000km
1989 4Runner, 300,000km - sold
isaac338 is offline
Old 08-26-2008, 11:51 AM   #15 (permalink)
thanks for all of the tips.
a sawzall and few blades later i have cut the bolt. the springs are now at my local spring shop getting re-arched and an extra leaf added. hopefully they have a new front bushings to press in because my old ones are shot.
upon further inspection of the bolt from the side that came apart, it is not a specialty bolt at all, just hardend. I thought it had a special shoulder on it but that is not the case.
__________________
88 4Runner
85 VW Scirocco
Old 08-27-2008, 08:48 AM   #16 (permalink)
4Crawler's Avatar
Yep, on the '84 and later trucks, the rear spring hanger bolt is plain since it goes through a sleeve in the bushing and thus does not need the shoulder. A Grade 5 or 8 9/16" bolt will work fine, or 8.8 or 10.9/14mm if you want to stay metric.
__________________
r.c.brown@ieee.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 08-27-2008, 10:51 AM   #17 (permalink)
i couldn't find a 14mm that was long enough in 10.9 so i went 9/16 grade 8
__________________
88 4Runner
85 VW Scirocco
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
IS it worth it? spring & shackle bushings? ogclew 86-95 Trucks & 4Runners 4 05-02-2008 02:42 PM
1st gen shackle and spring bushings...options thook 86-95 Trucks & 4Runners 12 05-04-2007 06:29 AM
leaf spring centering bolt??? richboss302 95.5-2004 Tacomas & 96-2002 4Runners 1 05-07-2006 07:25 PM
Spring Shackle Question forum95 95.5-2004 Tacomas & 96-2002 4Runners 11 01-18-2005 12:35 PM
Bolt on shackle tabs seafarinman 95.5-2004 Tacomas & 96-2002 4Runners 1 04-16-2003 06:50 PM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
