Rear window wont open :(
Old 10-15-2010, 06:48 AM
85 4runnen4life's Avatar
My 85 4Runner gave up finally on rolling the rear window up n down.
I cant get the door open with the window up so Im trying to do this fix from the inside. I havnt been able to find anything helpfull on the internet and my haynes manual only explains the exploded view of the components in there.
Has anyone had this problem and whats the best way to go about fixing it.
Thanks in advance
Old 10-15-2010, 07:44 AM
Outsane's Avatar
have you tried this page?
http://www.4crawler.com/4x4/CheapTri...arWindow.shtml
Old 10-15-2010, 08:28 AM
Etype R's Avatar
I have bypassed all factory wiring on mine. At first I was just running a on-off-on momentary switch off the battery, wired directly to the rear window motor. Now I am running 12voltguy's setup on all 3 of my power windows.
You can start by removing the access panel to the tailgate from inside, and unplug the window motor. Jump the motor leads off the battery, if it wants to go up, reverse your wires and it will roll down.
Old 10-15-2010, 09:37 AM
This wont smoke my motor?
Old 10-15-2010, 09:46 AM
Outsane's Avatar
I've done it this way with no problems..
Etype R's Avatar
Nope, its just a electric motor. I've been running mine like this since I got the truck.
Old 10-15-2010, 10:20 AM
Ok the motor has this lil wire harness coming off it with 4 wires.
2 White wires obviously ground wires
1 Red wire w/ white plug
1 Black wire w/ blue plug
what wires do I contact with battery leads to test motor?
what are the lil components pointed to with the yellow arrows?
Im really sorry for the n00by questions but Im learning alot from you guys every time Im on yotatech. I love this place..
Old 10-15-2010, 10:46 AM
Etype R's Avatar
There should be a plug with 2 wires off the motor, might be behind one of the brackets? Dig around more, its pretty simple. Just a lot of wiring for safety switches.
Old 10-15-2010, 11:59 AM
clemson4rnr's Avatar
Im pretty sure its not either of those... I just did mine the other night. The plug on my 1st gen is under the sheet metal right outside the bottom right corner of your picture. Just feel around you will find it. If not let me know and I can take a picture of where mine was.
Old 10-15-2010, 12:42 PM
Ur rught, its right where clemson4rnr discribed. I hooked it up like you said and it works fine. Ill clean and grease it while im in here. thanks for the ideas guys. I would never attempt this without some support line like this place. you guys kick ass!!!
Old 10-15-2010, 12:43 PM
ET
ET's Avatar
i've got a 95 so i'm not sure if it's the same for 80's models but did you check to make sure that you have the rear wiper off and the child window lock is off?
Old 10-15-2010, 02:11 PM
lol, yeah, when searching about this I was laughing about how many people started threads about this subject and the thread ended with a big DUHHH the child window lock was on.
My 85 has no child window lock option though.
Now Im in the process of learning how to wire in a switch for a direct jumper to this rear window motor. Im not much of an electrition either
Old 10-15-2010, 03:24 PM
I did this and it worked,
Do you by chance have a wire diagram of how to wire one of these on-off-onn switches..?
Old 10-15-2010, 04:02 PM
Etype R's Avatar
Here is a rough mspaint diagram I posted on mud http://forum.ih8mud.com/79-95-toyota...ml#post5871930
06-01-2021 01:51 PM
jasonty
41
12-23-2018 01:00 PM
coreyedwards7611
01-16-2016 06:38 PM
icentropy
07-14-2015 10:23 AM
coryc85
07-06-2015 04:07 AM
Quick Reply: Rear window wont open :(
