Nut / Bolt question - size/tpi
Old 05-10-2007, 04:41 PM
AndyL's Avatar
Just looking for some replacement nut & bolts for missing ones (unfortunately I need a new tap & die set - this is easy when it's imperial).
1988 4runner w/ 22RE
Need to know what size/thread the nuts on the exhaust manifold studs are (flange to exhaust)?
Grade / length / tpi for bolts on the factory roll bar?
Thanks in advance,
Andy
Old 05-11-2007, 05:17 AM
ewong's Avatar
Toyota uses JIC
so TYPICALLY its
8mm x1.25
10mmx1.25
My GUESS is the exhaust mani studs are 10mmx1.25...
(I have spare ones around so I dont bother to know anymore...)
Old 05-11-2007, 06:09 AM
waskillywabbit's Avatar
On the rollbar they are 7/16 - 20 as those are seat belt bolts
Holding down the rollbar are M10 x 1.25mm IIRC and they go through the floor so the length is not crucial
kgcwb44
01-29-2023 10:02 AM
tj884Rdlx
08-28-2015 12:04 PM
Gone Fission
07-24-2015 12:49 PM
HaydenConQueso
07-12-2015 05:22 PM
Cdn-wilderness
07-10-2015 07:43 PM
Quick Reply: Nut / Bolt question - size/tpi
