Nut / Bolt question - size/tpi
Just looking for some replacement nut & bolts for missing ones (unfortunately I need a new tap & die set - this is easy when it's imperial).
1988 4runner w/ 22RE Need to know what size/thread the nuts on the exhaust manifold studs are (flange to exhaust)? Grade / length / tpi for bolts on the factory roll bar? Thanks in advance, Andy |
Toyota uses JIC
so TYPICALLY its 8mm x1.25 10mmx1.25 My GUESS is the exhaust mani studs are 10mmx1.25... (I have spare ones around so I dont bother to know anymore...) |
On the rollbar they are 7/16 - 20 as those are seat belt bolts
Holding down the rollbar are M10 x 1.25mm IIRC and they go through the floor so the length is not crucial :guitar: |
