Last edit by: IB Advertising
Browse all: Engine Guides
- Toyota 4Runner 1984-1995 How to Change Engine Accessory Belts
Step by step instructions for do-it-yourself repairs
Noob 22re Question (belt tension)
Both the FSM and Haynes manual do a poor job of addressing this.
I'm tyring to locate the the correct bolt for controling the tension on the belt that goes around the power steering pump.
Unlike the altenator that pivots on the the bracket. It appears the PS pump is fixed. Is the adjustment made on the pulley to the left of the fuel pump?
The following users liked this post:
Jbfromga (05-09-2023)
I know this is an old post, but I've taken off my power steering belt and now I am unable to tighten it. The bolt that is shown above on the pulley bracket for adding tension to the p/s belt is not in place. There is clearly something threaded that lines up with the hole screwed into the back of the tension pulley but I think someone mickey moused this a bit.
Anyone know what to do?
Thanks for the confirmation Joe. There was a whole lot of head scratching going on....as soon as I loosened the tensioner pulley bolt, the pulley slid and loosened the belt. Right away I knew I was in trouble, because for the life of me, I couldn't figure out how to move it back up to re-add tension ???? Turns out I was missing a puzzle piece....the tension bolt! Its just gone. The guys up at nix have an 89 that just showed up... I'm going shoppin'!
dinks07
07-15-2015 05:34 PM
icentropy
07-14-2015 10:23 AM
