| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
High Output Alternators - Question About wiring
__________________
My Junk: 1985 Toyota 4 Runner DLX, 22RE, 5 SPD Mods: 4" TG 47" Front Springs w/ 5" Shackles, 3.5" Super Lift Rear Springs w/ 6" Shackles, TG Cross Over, TG Shock Hoops, 15x8 "Outlaw I" rims, 33x12.50 R15 BFG MT KM's, Doestch Tech 12" DT3000 shocks (4 corners), Custom Front Driveshaft w/ 12" Slip yoke & CV joint ground for higher angle, Toyota Fiberglass front fenders, Centerforce Dual Friction Clutch, SR5 Cluster My World: My 1985 4Runner's Profile My Car Domain Page. Last edited by LUV24BY; 06-13-2007 at 01:02 PM. |
#2 (permalink) |
when running shouldnt it be putting out closer to 14 volts? when my alt quit working my volt gauge was in the middle till my truck died. if you would ask me the alt is wither not wired up correctly or it is bad. and yes upgrading your wiring will give you more charging power. i believe its called the big 3 upgrade, do a search for it
__________________
my truck: 1987 pickup xtra cab sr5 22re 5 speed 4wd, 31x10.5's eb 261c cam, lce header, 2.25 exhaust 120amp Mr. Alternator rear lockrite, optima yellow top xrc8 winch & AOR bumper coming soon my bikes: 1980 Honda CX500-1997 honda cbr F3 |
#3 (permalink) |
I disconnected the OEM charge cable and installed a 1/0 welding cable
-- alt to battery -- battery to starter -- engine block ground to batt neg |
#4 (permalink) | |
Quote:
http://www.powermastermotorsports.com/charge_wires.html Though I don't think it's a PM alt, I think it's the same regardless. Can you completely bypass the stock wiring as you stated ewong? Won't this cause the SR5 volt gauge not to work? John
__________________
My Junk: 1985 Toyota 4 Runner DLX, 22RE, 5 SPD Mods: 4" TG 47" Front Springs w/ 5" Shackles, 3.5" Super Lift Rear Springs w/ 6" Shackles, TG Cross Over, TG Shock Hoops, 15x8 "Outlaw I" rims, 33x12.50 R15 BFG MT KM's, Doestch Tech 12" DT3000 shocks (4 corners), Custom Front Driveshaft w/ 12" Slip yoke & CV joint ground for higher angle, Toyota Fiberglass front fenders, Centerforce Dual Friction Clutch, SR5 Cluster My World: My 1985 4Runner's Profile My Car Domain Page. |
#5 (permalink) |
Thanks Notanymore - I did a search and got that information! It's much appreciated! Perhaps we should add this topic to the FAQ's!
![]() John
__________________
#6 (permalink) |
I am running a 160 amp in my rig. I have the stock harness in place, then an 8 gauge running from the external post directly to the battery.
__________________
-Rob Slightly Modified 2001 Tacoma - WATRD.COM WATTORA is becoming NWToys! Tread Lightly! certified Tread Trainer Search 100+ Toyota tech sites, including this one: Toyota Tech Search |
#7 (permalink) | |
Quote:
John
__________________
#8 (permalink) | |
Quote:
__________________
-Rob Slightly Modified 2001 Tacoma - WATRD.COM WATTORA is becoming NWToys! Tread Lightly! certified Tread Trainer Search 100+ Toyota tech sites, including this one: Toyota Tech Search Last edited by WATRD; 06-13-2007 at 04:55 PM. |
#9 (permalink) | |
Quote:
It sounds like you did the voltage test wrong. My stock alt. runs 15-16 volts running. Plus the voltage you posted shows the battery having more volts than the alt. I don't think an alt can charge a battery unless it's producing more voltage than the battery. And running heavier gauge wire is ALWAYS a good idea when your talking about transfering power heh. I've got 4 gauge wiring from my battery to starter, ground, and soon my alt.
__________________
Consequences dictate our course of action and it doesn't matter what's right. It's only wrong if you get caught. If consequences dictate my course of action I should play GOD and shoot you myself. I'm very tired of waiting. |
#10 (permalink) |
I got a 150A alternator from these guys:
http://www.mralternator.com/main.shtml I retained the factory wiring, but added an aux wiring kit from Summit. I believe it was a 2 or 4 gauge wire with inline fuse. This heavy gauge wire runs from the alt to the positive battery post. You can take a look at it on the next run we do if you like, although I ma sure you'd like to get this figured out sooner. The Summit part number was SUM-890025-1 and their description "ALT WIRE KIT 80-150 AMP". I can no longer find it on their website, but if you call they might be able to help you out. It was $19.95 on 12/05. You of course can get a heavy gauge wire from NAPA or local welding supply by the foot. You'll have to figure out your inline fuse holder on your own if you go that way.
__________________
================ 1990 4Runner | V6 3.4 | 5spd | 240 someoddthousand miles | SR5 | SAS | RLS | 35's | ARB | TJM | 217 to 1 | W8000 - four wheels | three sticks | two hands | one trail - visit the sticki chronicles
#11 (permalink) | |
Quote:
I will check again tonight and re-post the #'s!
__________________
#12 (permalink) | |
Quote:
John
__________________
#13 (permalink) |
I am a bit confused on "looped connector"... but my Summit wire had a factory crimped end for the bolt to pass through.
__________________
#14 (permalink) |
Yeah, I have that tendancy to confuse people!
![]() Looped Connector = Eyelet connector with the barrel on the end to crimp. I tested the ALT, it appears to be just holding. It's 12.25 @ the post of the ALT and 12.46 @ the terminal on the battery. Under load (best i can do, lights on, stereo on and at 2500RPM) the ALT meters 12.14 and 12.31 @ the battery. John
__________________
#15 (permalink) | |
Quote:
__________________
#16 (permalink) | |
Quote:
John
__________________
#17 (permalink) |
Bolt on the battery terminal, bolt on the alt.
__________________
| Tags |
| 22re, block, ground, main |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| high output alternator for 1st gen 22re? | wifesaysimadumbass | Offroad Tech | 3 | 08-01-2006 06:52 AM |
| How to test a high output alternator | Bumpin' Yota | 86-95 Trucks & 4Runners | 3 | 03-21-2006 10:38 AM |
| New Alternator... High output... | Ducky | 95.5-2004 Tacomas & 96-2002 4Runners | 8 | 12-22-2004 07:05 PM |
| High Output alternator install. | dbikeman | 95.5-2004 Tacomas & 96-2002 4Runners | 13 | 04-14-2004 06:24 PM |
| High output alternators | george16 | 95.5-2004 Tacomas & 96-2002 4Runners | 18 | 03-24-2004 09:13 PM |
