Help with 22re
Old 02-17-2009, 02:28 PM
Reaper's Avatar
Help with 22re
Hey Guys
I was driving home the other day and my truck just shut down on me so I pulled to the shoulder. I tryed to restart it but she will only crank she will not fire over. Had truck towed home. I found that the EFI fuse was blown under the hood, replaced the EFI relay to. With the key turned on i can 't hear the fuel pump running so I got a new pump put it in still can't hear pump running still turns over but no fire.
Any help
Old 02-17-2009, 02:56 PM
bigt's Avatar
that happen to me and was igniter/coil
but you can jump the duel pump in your diagnose box!
fp +b
Old 02-21-2009, 03:07 AM
pcmentor's Avatar
The fuel pump should only run when the switch in the AFM is on as when air is flowing through the meter. With the ignition on too.
JNapolitano
11-14-2019 07:46 PM
Stull
08-28-2015 05:53 AM
ia02
08-20-2015 11:04 AM
PlayAwhile
07-20-2015 11:36 AM
Quick Reply: Help with 22re
