Help with 22re
Hey Guys
I was driving home the other day and my truck just shut down on me so I pulled to the shoulder. I tryed to restart it but she will only crank she will not fire over. Had truck towed home. I found that the EFI fuse was blown under the hood, replaced the EFI relay to. With the key turned on i can 't hear the fuel pump running so I got a new pump put it in still can't hear pump running still turns over but no fire. Any help |
that happen to me and was igniter/coil
but you can jump the duel pump in your diagnose box! fp +b |
The fuel pump should only run when the switch in the AFM is on as when air is flowing through the meter. With the ignition on too.
