Heater Core Leaking
Old 12-08-2010, 04:18 PM
Challenger's Avatar
Heater Core Leaking
The other day my heater quit and then it started leaking on the passenger side floor. My truck has AC, is there anyway to remove the heater core without taking the truck in to have the AC removed at a shop?
Old 12-08-2010, 04:26 PM
windedwalrus's Avatar
yep the heater core is independent of the ac.
Old 12-08-2010, 04:49 PM
swampfox's Avatar
On a 86 model the evaporator needs to be remove to get access to the heater core.Not sure of your trucks year model.
Old 12-08-2010, 05:02 PM
muddpigg's Avatar
Guess what's sitting on the table next to me...my heater core. It may not be the actual heater core but the compression orings that seal the hard lines into the core. These little orings are a massive PITA to replace. If there's a trick I don't know it. This is my second time replacing them.
Old 12-08-2010, 05:09 PM
874runnersr5's Avatar
haha only trick i know is this getting the entire dash out, not so fun.
i put a bit of rtv around the oring just for safety because i reused them..
Old 12-08-2010, 05:32 PM
Challenger's Avatar
It's an 85. I took a look at it the other day and I would have to remove the entire dash to get it out.
Old 12-08-2010, 05:41 PM
waskillywabbit's Avatar
Yes. You have to pull the entire dash but it's not that bad if you have the FSM and see where all the bolts/nuts/screws are and what needs to come off first.
www.ncttora.com/fsm
:wabbit2:
Old 12-08-2010, 06:45 PM
myyota's Avatar
Its not hard to replace the heater core, it just looks hard because of everything you have to remove (the complete dash). Ive replaced heater cores in three 86 4Runners, and its a 4-5 hour job. You do not need to remove the a/c to change the heater core.
Old 12-09-2010, 06:58 AM
swampfox's Avatar
when removing the heater core on a 86 you can remove the glove box dash area ,unhook the evaporator hoses and remove the evaporator housing and access the heater core from the side through where the evaporator housing was. at least that how I done it.It has been around 8 years ago so I don't remember all the detail but the dash was not remove to do it.
the1998sr5
15
07-14-2020 08:35 PM
94 Newbie
08-06-2015 10:33 AM
this_guy
07-31-2015 01:27 PM
jjrbus
07-19-2015 02:06 PM
msane99
07-17-2015 10:13 AM
Quick Reply: Heater Core Leaking
