Extra play in steering wheel?
That is exactly what i did... didn't work w/the impact driver because the fan was in the way and I couldn't get a straight enough shot w/enough force to get it loose. I tried a few times, but I resorted to the largest flathead screw driver we had. One of those huge ones. I had a wrench on the jam screw and the turned the pre-load screw counter clockwise and it came loose w/a LOT of force. I had been spraying it w/wd40 for about a day too to help loosen it.
I haven't driven it yet, but I'm sure this was the problem. I will post back on the results.
#25
Any auto parts store will have that stuff, usually a small tube with a silver colored grease in it.
And for penetrating oil, WD40 is not a good choice, get something like PB Blaster or Kroil or something designed to penetrate and loosen rusted parts. One other thing to try is a screwdriver bit in a socket and then you can hold a wrench on the nut and then turn the screw with a ratchet.
#26
I would have tried the socket w/a screw driver but I didn't have the tool for that. I did get it loose though and I tightened the screw. Made my steering a lot better.
Thanks for the products you listed. They are on my list for things to get.
#29
that's what i did but i did notice more resistance in the steering so i thought I'd ask to be sure. what do you run as far as alignment. i just need to get through the winter and then i'm putting in my high steer. i think i have it about 1/8" toe out and its better then it was but then again i also adjusted the gear box.
Hamonacracker
07-17-2015 08:33 AM
