YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 84-85 Trucks & 4Runners
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 08-07-2008, 09:56 AM   #1 (permalink)
rocklover's Avatar
driveshaft question?
okay so my question is, will i be okay for a week if i only have 3 bolts holding it to the transfer case, and 2 bolts holding it to the third member until i can get to the junk yard next week?
__________________
1985 Extra Cab SR5, 5 Speed
-5 inch lift
-33x12.5 super swampers
-snorkel
-roll bar
-Winch bumper
-6 KC lights
-bullet holes
rocklover is offline
Sponsored Links
To remove this ad, register today!
Old 08-07-2008, 10:35 AM   #2 (permalink)
WFO
WFO's Avatar
Why dont you just go to the hardware store and get some bolts? I would trust bolts that arent the exact size over missing bolts.
WFO is offline
Old 08-07-2008, 12:08 PM   #3 (permalink)
x2. I use to carry a couple of spares in my 81. but a quick trip to the hardware store would be my suggestion as well.
tommytuttle is offline
Old 08-07-2008, 12:19 PM   #4 (permalink)
4Crawler's Avatar
Yes, 3 bolts is sketchy but 2 would be pretty risky. You can always pull some off the front shaft (unless that is what you have already done). Bolts are 10mm diameter or you can fit in some 3/8" ones for a temporary fix.
You can get new bolts and nuts at a Toyota parts dealer, not terribly expensive or you can order from Marlin Crawler or Trail Gear.
I picked up a full set of 16 from Toyota and kept my old bolts for trail spares. I used to carry some spare new bolts and had one truck on a trail in Moab lose his front shaft bolts. My spares got him back off the trail, but I never saw those bolts again, so now I only give away the beat up old bolts.
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs.
r.c.brown@ieee.org
TruckEditor@tlca.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 08-07-2008, 01:13 PM   #5 (permalink)
rocklover's Avatar
okay well heres my problem. i just got this truck like two weeks ago, but anyway s the driveshaft flange that connects to the third member doesnt line up right so i guess the guy only had 2 bolts holding it on. what should i do, drill the holes bigger on the third member so i can get 4 in there or just leave it as the two. i am going to the junk yard in an hour to go get a new flange to connect to the transfer case, but what should i do about the 3rd memebr not lining up?
__________________
-5 inch lift
-snorkel
-roll bar
-Winch bumper
-6 KC lights
-bullet holes
Old 08-07-2008, 01:22 PM   #6 (permalink)
4Crawler's Avatar
You can redrill the flange to fit the shaft. Just rotate the shaft flange 45 degrees on the mating flange then mark and drill 4 new holes:
Or you can pick up a set of multiple drilled flanges from Marlin Crawler or Trail Gear that have the 3 most common bolt patterns pre-drilled on them.
__________________
r.c.brown@ieee.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Driveshaft question 85.5Yota 86-95 Trucks & 4Runners 14 04-30-2008 12:00 PM
Driveshaft question fastkevman 86-95 Trucks & 4Runners 3 03-04-2008 01:40 PM
Driveshaft question. Island_Yota Pre 84 Trucks 2 11-22-2007 12:24 PM
Driveshaft Question (i think...) MikeKaduce Offroad Tech 4 05-03-2006 06:22 PM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
