Diff breather caps
Old Oct 30, 2008 | 04:38 PM
mountaineertom's Avatar
Diff breather caps
Does anyone know where you can get differential breather caps for the ends of the breather hoses? My son's doesn't have one on the rear and we're going to add a long hose for the front and I want to put a breather cap on it too.
Thanks.
Old Oct 30, 2008 | 07:19 PM
locked stock 84's Avatar
Not sure what you mean by cap, but most people just use a breather filter, available at checkers in the "import tuner" section for about $12.
Old Oct 30, 2008 | 07:30 PM
red97taco's Avatar
If you are looking for the original toyota ones, you have to go through the dealer, and the part number for it is 90930-03031(type with the threads) and90930-03136(type to put on the end of a hose).
After market kits are:
http://www.trail-gear.com/diff-breather.html
http://www.marlincrawler.com/htm/axles.htm#breather
A search on YOTATECH led me to this thread:
https://www.yotatech.com/forums/f116...eather-113377/
There are many different ideas out there. I still run the toyota ones, but the one that trail gear sells looks like a cool, smart idea because you don't have to worry about any water getting in it. Anyone ever run it? And pros/cons to it?
Old Oct 30, 2008 | 09:27 PM
4Crawler's Avatar
A filter of some sort is preferable to the stock breather. Why? The breather is designed to let hot air out (good thing) but not let air in when the axle cools. This can cause problems if you drive into deep water long enough to cool the axle off. This causes a vacuum to form inside the axle and that could cause water to get sucked in past a seal. With an open filter, air can flow in and out to equalize the pressure in the axle hot or cold.
Old Oct 30, 2008 | 10:59 PM
XtraSlow_XtraCab's Avatar
I've heard of someone clamping see-through hose to the original fitting, running into the bed or next to the filler neck, and clamping on a fuel filter at the end. Sounds like it'd work.. filter... flow... CHEAP
Old Oct 31, 2008 | 04:17 AM
Thanks, i was looking for the push in type that goes on the end of a hose, but I might try a small filter if I can find one.
My ATV has the same thing as the kit at trail gear. I've had no problems with it since I got the ATV in 2002.
Old Nov 4, 2008 | 01:28 PM
Ok, I got 2 new 1/4 barbed unions (p/n 90404-51026) to put in the diff housings. Should thread tape be used on these, or does it seal up good without it?
I had also ordered 2 push in breather caps (p/n 90930-03136, 5/16 barbed end) for the ends of the hoses, but may end up using the small filters instead.
Thanks for all the tips.
Old Nov 4, 2008 | 02:41 PM
Scooby098's Avatar
use thread tape
jashoeuh
Nov 18, 2024 08:08 AM
krimsonone
Sep 13, 2024 09:33 AM
justdifferentials
Just Differentials
Sep 17, 2015 06:14 PM
Steven.m.paulk
Jul 24, 2015 01:44 PM
scottyg486
Jul 19, 2015 05:34 PM
