Cleaning the Fuel Tank
Old 10-22-2010, 11:28 AM
modlite's Avatar
On our 85 4Runner we're having problems with Injectors getting clogged, we were told we need to clean the fuel tank out, and change the fuel filter.
What is the best way to go about cleaning out the fuel tank?
I was thinking about getting something like this:
http://mystarbrite.com/startron//con...5/125/lang,en/
Running putting it in the tank, shake the truck around, let it sit, drain the tank, then flush some fresh fuel through it.
What are your guys' recommendations on this? Can I clean the tank with it in the truck or should i just drop it out?
Old 10-22-2010, 12:03 PM
mightymouse's Avatar
drop the tank and do it right.
Old 10-22-2010, 12:26 PM
myyota's Avatar
If the tank is real rusty on the inside, you will need to replace the tank or the rust will come back, its just a matter of time before it does.
Old 10-24-2010, 05:36 AM
samiam39's Avatar
you can buy a kit to clean and epoxy coat the interior of the tank its product call por15 fuel tank system, or go get another tank at the bone yard
Old 10-24-2010, 08:05 AM
85TurboRunner's Avatar
years ago when I had a rusty tank i removed it and threw some rocks in it and shook it around till the rust was beat off the sides of the tank. I vacuumed out all the rust and used this stuff to seal the tank.
http://www.ahwooga.com/detail.asp?id=9453
I didnt buy from that particular company but that is the product I used.
Old 10-24-2010, 02:52 PM
modlite's Avatar
K we dropped the tank late last night, and cleaned out all the crap in there.
I must say this is the easiest tank i've ever dropped. Easy to drain, no straps, and easy to get to all the fittings on top.
One problem I encountered though, was we bent the fuel line fitting on top.
Looks like that one. It has a kink in it, I didn't want to straighten it because I feared it would break. The truck runs perfectly fine, but the new fuel pump is a little loud and I'm fearing it's because of this kinked line.
Does anyone know where we can buy a new one of those assemblies that holds the fuel pump and everything or should I just start asking people who are parting out trucks?
Old 10-24-2010, 04:33 PM
dealer part sorry and it's around 100 bucks maybe 80 or so i haven't purchased one in a while.
Old 10-24-2010, 05:28 PM
modlite's Avatar
Alright that's what I figured. Do you know where I can find a part number for that or should I just go to the dealer?
I was trying to find it on some of the toyota wholesale sites and had no luck.
Eggslinger
06-08-2019 03:32 PM
Doug4320
03-24-2018 10:11 PM
skoti89
09-11-2015 07:46 AM
pyramid
07-30-2015 10:05 AM
TURBOrunnerNM
07-22-2015 11:01 AM
Quick Reply: Cleaning the Fuel Tank
