black sut in clutch master cylinder - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 84-85 Trucks & 4Runners
New! Use your Facebook to securely log into this site, click logo to login
Welcome to Yotatech!
Welcome to Yotatech,
Old 12-18-2009, 04:53 PM   #1 (permalink)
went to make a run and was checking fluids and noticed clutch was a little low, proceeded to add a little fluid and there was a blackish dark gray substance kind of swirled around in resivoir, i over filled to make it run out adjusted level and went on my way later on pushed clutch felt funny pressed again to the floor it went jumped out to see if fluid was gone, it was still full but almost black double clutched it home, figured needs new master and slave but would like ideas. what would cause the black sut
brianrbhutch is offline
Old 12-19-2009, 05:59 PM   #2 (permalink)
myyota's Avatar
It wouldn`t be a bad idea to replace both and flush the lines.
__________________
86 Toyota 4Runner
Solid Axle Swap, 16'' of lift, 37x12.50-15 GoodYear MTR tires, Trail Gear High Steer, 5 speed manual trans swap, InchWorm Duel Cases With 5.7 Gears, 63'' Chevy Springs In The Rear, 5'' Trail Gear Springs In Front, Marlin Crawler Third Members, 4.88 Gears With A Detroit In The Rear, High Pinion Front With 4.88 Gears And An ARB, Downey Header, AFM Upgrade, Optima Battery, Trail Gear Sliders, Addicted Offroad Front Bumper, Trail Gear Rear Bumper.
myyota is offline
Old 12-19-2009, 06:02 PM   #3 (permalink)
4Crawler's Avatar
Could be the fluid just got old, it'll turn very dark with time and not flushing it. Or it could be a seal or flex line had started to disintegrate and it was than black rubber residue you saw.
__________________
1985 Toyota 4Runner SR-5, 22REC engine, dual t-cases, 4.88 gears, dual ARBs, 33x10.50 BFGs or 35x12.50 MTRs
r.c.brown@ieee.org
TruckEditor@tlca.org
Project: 4Crawler
4Crawler OffRoad
Gettin'Off 4WD Club
4Crawler is offline
Old 01-05-2010, 03:18 PM   #4 (permalink)
stormin94's Avatar
What kind of fluid does it take? Is it just simply "clutch fluid"?
__________________
1994 Toyota 4Runner SR5 4X4
221,500 miles and counting
3.0 V6, 5 speed
10/15 MPG city/hwy(with 33's)
Current Mods
Headers, 2.5" Flowmaster custom exhaust, K&N FIPK
KC Daylighters, electric fan
Ranchos x4, 2" Lift Downey coils
33-12.50 M/T's, 1" t-bar lift, 1" body lift
Tow pkg w/ lighthookups
Silverstar Headlights, Pioneer Deck w/XM
Brushguard
250Watt JLAudio 8" W3 Sub
Future Mods
12V Aux outlet-400/800peak inverter
roof basket/lights
Air locker
4.88 gears
H.O. Alternator
stormin94 is online now
Old 01-05-2010, 03:21 PM   #5 (permalink)
ToyoTech559's Avatar
brake fluid goes in clutch reservoir
DOT 3 should be fine
ToyoTech559 is offline
Old 01-05-2010, 03:22 PM   #6 (permalink)
stormin94's Avatar
Ok, cool. Thanks.
__________________
3.0 V6, 5 speed
Current Mods
Brushguard
Future Mods
roof basket/lights
Air locker
4.88 gears
H.O. Alternator
Old 01-05-2010, 03:24 PM   #7 (permalink)
Kiroshu's Avatar
A flush is not neccesary and brake fluid does not get "old" It either gets contaminated or dirty. Make sure your reservior is on all the way and make sure its not leaking anywhere. If it was low its prop leaking look at the rubber line down near the trans. Its it saturated? Thats prob the issue. Brake fluid always.
__________________
"Why not stay OEM your truck will last longer?"
"I love what you do for me Toyota."
"Moving Forward."
"If a yota can wiggle It ain't stuck."
"No matter what you do that timing chain will beat the guidles(Dampers) 1v1."
"(TTT) Toyota Tough Truck."
Kiroshu is offline
Old 01-05-2010, 03:29 PM   #8 (permalink)
Quote:
in a sense it does get old, well kinda. even if it doesnt get dirty or contaminated by wear and tear. brake fluid absorbs moisture which is in the air around us. moisture will break down the fluid and its best to change it out every 2 years
Old 01-05-2010, 03:39 PM   #9 (permalink)
stormin94's Avatar
I might have a leak somewhere, since there's some fluid near the top of the trans that's leaking from somewhere. And my clutch pedal was kind of stiff today. I'll have to check that out tomorrow, since it's getting dark out right now.
__________________
3.0 V6, 5 speed
Current Mods
Brushguard
Future Mods
roof basket/lights
Air locker
4.88 gears
H.O. Alternator
Tags
95, bad, black, clutch, cylinder, dirty, fluid, master, problems, reservoir, resevoiur, residue, runner, toyota, turn
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Contact Us - YotaTech - Archive -
Top
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
2010 InternetBrands, Inc.
