85 4Runner driver floor pan and rocker panels
HELP! My driver side floor pan is rusted out around the body mount. Does anyone know where to get a replacement for pan? I just need the driver side... the rest of the floor is good to near perfect. I could probably fab something up, but I've never done that and I want to get back close to original.
I found steel rocker panels and rear quarters here: http://www.alfaparts.net/toyota4r.htm They also have tailgate replacement panels. toyotafiberglass.com is also a good place to get fenders, hoods, door skins, tailgate skins and the "L trim" on the hard top.
*DISCLAIMER* - I found these parts by searching. I don't endorse or have any affiliation with this company. I'm just a guy trying to solve my problems and passing along the info I get to you.
If you can`t find new replacement parts that you need, then see if you can find a wrecked truck or 4Runner and cut the pieces off that you need, you might try a wrecking yard.
I have the same problem with my 83 4wd pickup, i have ben unable to find replacment panles for that part of my truck. im about to try to fab something. if any one has more info on this it would be a grat help.
thanks
thanks
Jnkml
07-06-2015 01:20 PM
FS[SouthEast]: 1st Gen 4Runner Slider Window, Driver Side
coryc85
07-06-2015 04:07 AM
