YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 84-85 Trucks & 4Runners
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 08-24-2008, 10:43 PM   #1 (permalink)
Exclamation 84 pickup charge problem
i have a 84 pickup 4x4, it has the 22r with the external regulated altinator. at random times the truck will stop charging. both the charge light and the brake light come on. sometimes it won't charge for 50 miles, the next time for 2 miles. i got it checked out by toyota and the told me to replace the regulator and altinator, so i did. the same thing happened, so i went back and they replaced both on warranty, still the same thing. sometimes i'll be able to drive for weeks before this happens, then the next time days. but eventually it does charge again. any one have any thoughts on what the problem might be. it's killed my battery a couple of times already. i carry a spare with me just in case.
abrelm is offline
Sponsored Links
To remove this ad, register today!
Old 08-25-2008, 01:07 AM   #2 (permalink)
XtraSlow_XtraCab's Avatar
By the external regulator, are you referring to the 'IC Regulator' located on the driver side fender?
The charging system is very basic really and you've covered the major points.
As you're driving try and monitor what goes on as charging fails and remedies. See if there is a consistent pattern. It could be as simple as a positive wire grounding out to steel, or a ground losing contact, etc. and sharp turning affects it.
It could also be a bad battery (and perhaps) a failing charge-light-relay.
My only other suggestion is that you investigate how the voltage regulators operate on these trucks (I don't know, never had a problem). Older style regulators are a points-contact setup (similar to old distributors). There are actually adjustable "gaps" between these points in voltage regulators (like spark plugs for example) that must be set.
However, that is IF the regulator still operates in such an ancient fashion. If it does, your FSM or even maybe your Chilton's book should have all of that... You do have those RIGHT?!?! There lifesavers!
__________________
The little truck putt-putts down the road.
The little truck putts slowly.
Cars honk in frustration at the little truck that putts slowly.
The flooded highway is four feet deep in water.
The frustrated car stops at the waterline, scared to swim.
The little truck putts on through.
XtraSlow_XtraCab is offline
Old 08-25-2008, 01:23 AM   #3 (permalink)
Oh, try checking the fusible links!
Ok, I looked through a 1985 FSM and noticed this little bit. The two "big fuses" are fusible links and the smaller, circled fuses are for engine and charge or something:
__________________
Old 08-25-2008, 08:50 AM   #4 (permalink)
taconasty's Avatar
you might check the grounds, i cleaned up and replaced one of mine this weekend and it charges great and starts faster.
taconasty is offline
Old 08-25-2008, 09:27 AM   #5 (permalink)
putneysmachine's Avatar
Quote:
Yep, sounds like you are having a grounding issue. Remove the ground battery cable at the frame side and wire brush the hell out of it, the spot on the frame where is it supposed to ground and the bolt that holds it on. If there is ANY corrosion, paint, dirt, etc. It will cause that issue. Make sure your cable end at the battery is holding properly. The bolt will tighten, but still not be holding the post properly.
Keep us posted
__________________
www.putneyscustommachine.com
putneysmachine is offline
Old 08-25-2008, 09:53 PM   #6 (permalink)
Exclamation
i've checked every ground that i could find, cleaned it and re attached. i checked the battery terminals. everything seams fine. fuses are all good. i tested all the wires that i was told to by the hanes manual. everything seams to check out. i'm stumped. as far as the pattern as it happens, it's completely random. i'm driving speed limit for a while and it happens, when i start the truck, it sometimes happens. and it turns back on whenever it want's. maybe i should replace the battery? it's the only thing i have not changed that i know of. any other suggestions please let me know. at this point i'll try anything.
abrelm is offline
Old 08-26-2008, 03:18 PM   #7 (permalink)
Quote:
found the problem. they gave me the wrong voltage regulator. there are 2 different ones for my truck. the one that works is part #27700-38113. seems to be working so far.
abrelm is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
86 pickup problem Jay1 86-95 Trucks & 4Runners 4 05-17-2008 03:20 AM
93 pickup clutch problem!! kmd1776 86-95 Trucks & 4Runners 3 01-16-2008 04:34 AM
84 pickup ignition problem? Mister Willie 84-85 Trucks & 4Runners 1 04-09-2007 02:45 PM
steering problem on my 82 pickup dellstoptoyota Maintenance & Repair Archives 2 09-16-2005 10:52 PM
89 pickup problem?? blasterman Offroad Tech 3 05-26-2005 10:26 AM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
