5.29's breaking
Originally Posted by mike_d
quick question about this. i'm planning on getting 4.88's this spring. i'm at the mercy of someone else to do the installation, because i don't know how to do it, nor do i have the space to do the work. so if someone else does the installation, how do i know if it's done right and what do i need to be picky about?
If they say no, leave.
If they say yes, ask them how many times.
If they give you a number less than 5, leave.
Bonus points if they've done it before on a Toyota 8" rear end.
**This method is especially useful if you're good at picking out liars. A good way to test their knowledge is to ask something only a person who's done it before would know. What that something is, I have no idea.**
Follow that and the rest of the before and after procedures listed above and you'll be fine.
Originally Posted by SRV1
It is 100% true that 5.29's and 5.71 can break under load.
While a proper setup IS CRITICAL, even the best setup 5.29's can and will break under hard useage. I've gone thru 4 sets of 5.29's since 2001- the longest a set lasted was about 28000 miles, the shortest less than a week. I've had the pinion break, I've had a ring gear break, I've broken a front and rear set, and two rear sets fail. I'm spooled front and rear after blowing up my last set of gears on front Detroit. Yeah, even the weak link Detroit held up when the gears blew.
While I do "get it" on occasion, the majority of my wheelin' is in the 3.5 (1 to 5 scale) and below range. Perhaps once a year I'll run a 4 or 4+ trail, but frankly I'm tired of fixing the rig after every run. to much $$$. The truely hard core guys break Toy thirds pretty routinely, and most of them have moved on to heavier axles or lighter rigs.
If I had it to do again I'd run 4.56's or 4.88's and deeper t'case gears to make up the difference on the trail.
Originally Posted by crawler#976
It is 100% true that ALL GEARS can break under load.
#25
check my thread titled:
Who/What is to blame?
#26
Well of course ANything can break. And lockers is a great way to test ALL the parts in the axles...
I know a guy who breaks the stock 4.10s on regular basis, so does that mean they're too weak?
Certainly it is a fact that the higher numerically the ratio gets the weaker the gears get. But if the question is should you avoid them in the average rig, I think the simplest answer is that are tens of thousands of them out there doing just fine.
If your trail rig, rock crawler, big engine rig, or even personal driving habits are causing breakage (of any drivetrain part) then you need to analyze what to do stop that - generally beefier parts, maybe a different setup, but sometimes it might be simpler like learn to not dump the clutch while the tires are wedged between a rock and hard place...
Once again the real answer is "it depends."
#27
I respectfully disagree with your statement and Zuk's site.
James
#28
i dont do too hardcore of 'wheelin. most of its mudding, hill climbing, and trails. nothing that will put too much strain on the gears. i think i'll go with 5.29's, and 35's. wha cha cha cha! too bad i cant get them until i have put my hy-steer and allpro long travel on my truck. theres about $1800. then i have to save up for the gears and install. and then my dad will probably buy me tires
JookUpVandetti
09-30-2015 08:58 AM
FS[PacNorWest]: 1987 4Runner SAS, 22RE, 5Spd, Dual Cases, etc
toyotasaurus
09-24-2015 03:30 PM
