4WD makes awful noise
I just scored a 84 yota longbox, it's in pretty sweet condition but in 4x4 it makes an awful noise when I take my foot off the throttle or when I am traveling at low speed or near 1st gear idle. Should I assume that it's the hubs? It drives fine in 2 wheel, otherwise truck seems minty with 150 km and no rust. I hear these solid axles are supposed to be bulletproof what do you experts say?
Thanks a lot,
Rosludos
Thanks a lot,
Rosludos
Not really anything to upgrade. Maybe a pair of these...
http://www.longfieldsuperaxles.com/p...INNER-HUB-GEAR
...but honestly, no real reason to do so in an all stock axle.
Lots of good rebuild info here. Good links within some posts too.
https://www.yotatech.com/forums/f120...s-here-239443/
And as mentioned, check those wheel bearings and either replace or clean and repack as indicated.
Jeffreynmandy
07-18-2015 08:26 AM
