22RE Staring Problem
I have a problem with my starter sounds like contacts so I changed the contacts same problem so I changed the whole starter same problem I checked the relay and it looks good to me. When I turn the key it makes a clicking sound like the battery is dead but I know its not. I have to keep turning the key over and over sometimes for 5-10 mins and finally it will turn over blowing smoke out the tail pipe. Does anybody know what the problem could be. Thanks
have you checked the teeth on the flywheel? pull the starter and turn the motor over by hand while inspecting the gear ring.
Perform a simple voltage test at the starter when you get the click:
- http://www.4crawler.com/4x4/CheapTri...shtml#EasyTest
If you see more than a 1/2 volt drop to the starter solenoid you may have an electrical issue upstream from the starter, some options to fix those on the web page below:
- http://www.4crawler.com/4x4/CheapTri...l#OtherOptions
Doing that simple voltage test (under load) posted earlier will tell you where to look for the cause of the problem:
steve miller
10-10-2015 01:40 AM
Odin
07-15-2015 09:28 PM
