22RE to 22R Conversion?
Old Sep 25, 2008 | 07:52 AM
JasonWin's Avatar
Question 22RE to 22R Conversion?
Alright so just yesterday I found out that the motor in my truck is pretty much toast. low compression in two cylinders (one around 70 and one around 40) So right now I'm looking for anouther motor to swap in. Even if it's only untill I rebuild the 22RE myself or something. I was just wondering what would be involved in swapping a 22r in place of my 22RE? I found an 83 pickup I can get for fairly cheap with a spare engine. I'm fairly mechanically inclined just right now don't have much knowledge on the subject
Old Sep 26, 2008 | 06:03 PM
escodan760's Avatar
im looking to convert a 1986 4WD 22r to a 1992 or 1993 efi 2WD. does anyone know if it makes a difference if its 2wd or 4wd, new or older efi make a difference. I have the motor harness and ecu
escodan760's Avatar
send me a mesasge with any info
Old Sep 26, 2008 | 07:08 PM
91Toyota's Avatar
Oil pan is different. 2wd oil pan wont work on a 4wd truck
Old Sep 28, 2008 | 06:40 PM
hmmwv15's Avatar
Make a new post, and leave this thread for the OP's subject please.
It's less confusing to everyone else.
For the OP:
I wouldn't go carbed unless the truck sees minimal offroad use, on less inclined surfaces. If you can use that block and head, and just swap your exhisting EFI parts on the engine that would probably be the best route. Essentially just doing an EFI swap on a carbed engine, and I'm sure there will be more helpful threads on that. I would help but I'm in the same boat as you for the knowledge aspect! Good luck.
Old Sep 28, 2008 | 07:36 PM
eatmorechicken's Avatar
Basically all you have to do is bolt your efi stuff on to the motor and put a block off plate where the fuel pump was for the carb. The block and head are the same. I just put a 22r block and head in my 85 efi 4runner and everything just bolts right up.
sandyota
Feb 4, 2021 11:16 AM
cars-guy
Aug 16, 2020 06:59 AM
dumpster84
Apr 30, 2016 06:03 AM
coleypull15
Nov 3, 2015 07:41 AM
cars-guy
Jul 11, 2015 07:51 PM
