Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
I need a little help with getting my oil pump off to replace the seals. I've got the first pully off, now I need to get the balancer off. Any tricks on how to get this darn thing off?
__________________
84 Yota 4x4 22R 9" Lift 35" mudders 3" SMOKE STACK "REDNECK RIG" |
| Sponsored Links |
#2 (permalink) |
Sponsoring Member
Find a FSM or try AUTOZONE's online manuals in the "repair info" on their website.
__________________
WabFab Off-Road, LLC www.myspace.com/wabfab 6th Annual South East 4Runner Jamboree, May 22-25, 2009 WabFab Off-Road Salvation Army Online Kettle |
#3 (permalink) |
Autozones tells me to remove the oil pan, strainer ect but the oil pump is mounted to the front of the engine, why would I need to remove all that stuff?
__________________
#4 (permalink) |
I dont have a breaker bar so whats the next easiest way to get this !@#$ balancer off!?!
__________________
#5 (permalink) | |
Quote:
you could go to checker and in there loan a tool they have a puller that works just for these..... or us a big screw driver and gently push on the pulley from behind. go from side to side, also try some spray lube to loosen things up.
__________________
It's a yota and it has some tires. |
#6 (permalink) |
thanks...I went and got a breaker bar from my buddy's shop and did the crank the engine method. worked good!
__________________
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| oil pump removal | King Supreme | 86-95 Trucks & 4Runners | 6 | 07-14-2008 10:59 PM |
| 22r oil pump leak @ timing cover... | ncpaladin | 86-95 Trucks & 4Runners | 10 | 07-13-2008 07:47 PM |
| 22R-E new oil pump. Where do I go for oil pressure? | byrdman | 86-95 Trucks & 4Runners | 5 | 07-05-2008 12:54 PM |
| 22r oil pump..... again | FenderJazz | 86-95 Trucks & 4Runners | 2 | 06-08-2006 05:13 PM |
| Press diff between 22R/E and turbo oil pump? | Arnold | 95.5-2004 Tacomas & 96-2002 4Runners | 0 | 09-09-2002 08:39 AM |
