22r no compression on 3 and 4 cyl
Just picked up a 85 extra cab in hopes of rescuing it.
Was running like crap, so did a compression test and 0 compression on 3 and 4 cylinder.
When running im getting a loud top end sound, doesn't sound like bottom end as it is higher pitched.
Pulled valve cover resset valve clearance hoping for a valve that wasn't closing all the way. And still no compression on three and four and I mean 0 not even moving gauge.
Any ideas?
Any ideas?
mine had no coolant/oil mix.The gasket was blown between the clyinders.Compression was really low due to it blowing back thru the intake valves.It blew, sounded like a rod knock, and had no power.Only drove it a 1/4 mile when it happened.
Bourbonblues
12-15-2017 05:43 PM
