22r 32/36 dfev
22r 32/36 dfev
So I picked this 32/36 carb kit up off craigslist for 80 bucks, it came with some adapter plates and an air filter but they aren't for this truck.
Anyways, it's a DFEV, not a DGEV, from what I understand the only difference between the two is that one if mirrored from the other, not really sure though.
Has anybody had any luck getting a DFEV mounted up to their 22R?
Should I just sell this thing and buy a proper DGEV?
Thanks.
Thanks.
If I recall correctly, the DFEV has the throttle linkage set up wrong for the 22r, unless you make the throttle cable pull from the other side or something.
Basically, I would clean this up(if it needs it) and sell it so you have the money to buy the correct DGV or DGEV
buckz6319
08-05-2017 03:50 AM
Toys4parts
09-26-2015 01:56 PM
