1984 pickup cab mount pictures??
first hello everyone, recently purchased 84 sr5 extra cab to "fix up" for my son, and one of the MANY things needing to be done is removal of body lift and repair of cab mounts, appears that whoever put on body lift didn't do it correctly and/or over the years the mounts just broke. no cancer in mount areas but cab is just sitting on mounts not attached , that is were the dimple is in the floor is just sitting on top of spacer. my question is how are the mounts supposed to attach to the floor? dimpled washer on inside of cab perhaps? any one have a picture? sure would be helpful. currently posting from work but will post pics of what I have when I get home this evening. TIA any/ all help you provide.
mount from below
inside cab
things done so far
stripped front axle down to empty housing
replaced all bearings not including third member
degreased under carrage found source of oil leak, pressure sending unit on side of block
lots of rattle can paint to removed parts
and the fun begins
Scott
mount from below
inside cab
things done so far
and the fun begins
Scott
now if only I can get er done in the two years before he graduates
thanks for the link, very informative page. guess I better spend some time online before I get too far into this truck, gonna be mostly stock except for a suspension lift and few other small mods, thats what I'll do for him anyway, who knows what he may do one day
Regency
20
01-03-2020 07:43 PM
