1984 pickup cab mount pictures??
first hello everyone, recently purchased 84 sr5 extra cab to "fix up" for my son, and one of the MANY things needing to be done is removal of body lift and repair of cab mounts, appears that whoever put on body lift didn't do it correctly and/or over the years the mounts just broke. no cancer in mount areas but cab is just sitting on mounts not attached , that is were the dimple is in the floor is just sitting on top of spacer. my question is how are the mounts supposed to attach to the floor? dimpled washer on inside of cab perhaps? any one have a picture? sure would be helpful. currently posting from work but will post pics of what I have when I get home this evening. TIA any/ all help you provide.
mount from below http://i1173.photobucket.com/albums/...ountbottom.jpg inside cab http://i1173.photobucket.com/albums/...4/mounttop.jpg things done so far stripped front axle down to empty housing replaced all bearings not including third member degreased under carrage found source of oil leak, pressure sending unit on side of block lots of rattle can paint to removed parts and the fun begins http://i1173.photobucket.com/albums/...car64/fun1.jpg Scott |
Welcome toy84, Im not sure on the mounts but pictures would help.. Good luck on the truck, your son is lucky to have you doing this for him..
Look at body lift pics on 4crawler.com
:wabbit2: |
Originally Posted by Bigdady
(Post 51926682)
now if only I can get er done in the two years before he graduates :welder: |
Originally Posted by waskillywabbit
(Post 51926684)
4crawler.com
:wabbit2: |
