Pre 84 Trucks 1st gen pickups
why does my 83 hilux have Bad compression
Old 06-24-2011, 05:11 PM
BURR2OF4's Avatar
I over heated my motor and ended up with water in the oil, so i figured it was a blown head gasket. i took the head to the machine shop and had it cleand and inspected along with getting it milled and having the valves ground. i put the head and a new gasket on last night and today i did a compression test and #2 has only 30 psi. i took the head back off and inspected the cylinder but i couldnt see any dammage. does anyone know what is causing my leak? i figured for a leak that bad i should see a big crack in the cylinder wall but i dont.
Old 06-25-2011, 02:00 PM
Thelast83inNJ's Avatar
Valve clearance too tight, hanging valve open slightly?
Old 06-27-2011, 01:31 PM
83's Avatar
Did you make sure the block was completely level? Not warped at all?
Old 06-27-2011, 07:53 PM
BURR2OF4's Avatar
no i just cleaned off the mating surfaces and put the head back on with a new gasket.
Old 06-27-2011, 08:34 PM
toyotacharles's Avatar
check the deck and double check valve clearances
Old 06-28-2011, 06:23 AM
83's Avatar
Especially if you overheated, making sure both the head and block are completely level is a good thing.
Old 07-07-2011, 02:45 PM
BURR2OF4's Avatar
it was the valve lash. thanks
Old 07-08-2011, 06:10 AM
83's Avatar
Glad you got it figured out, and it was something easy & cheap!
nvdesertrunner
05-11-2020 08:18 PM
JNapolitano
11-14-2019 07:46 PM
wafoogalla
11-02-2016 11:02 AM
Sidherish
08-02-2015 01:42 PM
thefishguy77
07-30-2015 10:59 AM
Quick Reply: why does my 83 hilux have Bad compression
