Pre 84 Trucks 1st gen pickups
Weird charging problem
Old 03-03-2011, 09:56 PM
theslowone's Avatar
My truck came with an externally regulated alt. The previous owner swapped in and internally regulated alt and hooked up the red wire from the connector. And I swapped higher amp ( his 25 amp mine 55 amp Toyota reman) alt made for the 22r. It had two connectors I hooked them up and everything worked fine most of the time. I taped the second to the yellow wire and it sender voltage and runs great.
But sometimes,getting more common, the truck will not charge till u rev it to about 3k then from the pass side can hear a relay ping and the volt meter jumps to 14 and it is charging. And clue why it is doing that? And what exactly is over there to make that noise ?
rondogracing
Engine Swaps
16
08-24-2015 03:02 AM
80Truck
07-24-2015 03:12 PM
yourrealdad
07-21-2015 11:13 AM
icentropy
07-14-2015 10:23 AM
jon.r
07-11-2015 03:34 PM
Quick Reply: Weird charging problem
