Pre 84 Trucks 1st gen pickups
Vented Rotor Question
Old 06-26-2011, 02:29 PM
541SR5's Avatar
I will be doing a vented rotor swap on my '81 next weekend. Will I need to use longer wheel studs or can I reuse the stock ones?
Also I what size wheel spacers will I need to have the calipers clear my rims? I'm running 15x8s will a 3.75 backspacing.
Thanks!
Old 06-26-2011, 02:36 PM
waskillywabbit's Avatar
No. Yes. 1.5"
:wabbit2:
Old 06-26-2011, 02:50 PM
suncomb1's Avatar
Heh Waskillywabbit. I am doing a vented rotor-V6 caliber swap on my 1983 4x4. My wheels are 15x8.5 Enkie 30 series with 3.75 backspacing. Must I use a 1.5 spacer also? If so why, the calibers look like they will clear okay but then again you do this kind of stuff for a living.
Old 06-26-2011, 04:02 PM
V6 vented calipers are way fatter and won't clear without wheel spacers. I use 1.5" as it matches IFS rear width if you swap.
:wabbit2:
Old 06-27-2011, 05:03 AM
541SR5's Avatar
Do you have to do any kind of grinding to the caliper or back of the rotor to get them to fit? (I think I read that somewhere on the net).
Old 06-27-2011, 06:13 AM
fountainrunner's Avatar
Just go with the wheel spacers. I tried grinding mine down and still needed the wheel spacers. So know i have one retarded looking caliper.
garagespace
10-11-2015 10:59 AM
88sasturbotoy
08-11-2015 01:56 AM
TJWilly
07-31-2015 02:05 PM
britishdudes2dr
07-25-2015 06:47 AM
msane99
07-11-2015 08:08 PM
Quick Reply: Vented Rotor Question
