electric fuel pump on my 82' - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > Pre 84 Trucks
Welcome to Yotatech!
Welcome to Yotatech,
Old 10-12-2009, 12:36 AM   #1 (permalink)
ktown808's Avatar
ok so heres the deal took out the 22r and dropped in a 20r but now i need to wire a electric fuel pump was just wondering if anyone has done this and has some tips they would like to share, like what did you hook the pump up to accessory wire or whatever and another thing is it possible to remove the charcoal canister and run just one line from the tank so any tips or tricks will help thanks
__________________
1982 Toyota longbed 4x4, 15x8 rockcrawler streetlocks wraped with 31x10.5 BFG MT
ktown808 is offline
Old 10-12-2009, 04:27 AM   #2 (permalink)
suncomb1's Avatar
Whatever electric pump you use you need to know its maximum amps. You need a relay and auto resetting circuit breaker sized larger then the max rating of the electric pump. I run a Mallory Model 110 using a relay and 15amp auto reset circuit breaker. The relay is energized when I turn on my ignition switch and the pump power comes directly from the battery through the circuit breaker. You could use a fuse if you prefer.
I moved the fuel tank canister from the firewall and installed it in the same place as the carb canister on the right fenderwell. I installed one hose with the jet from the canister to my intake manifold.
suncomb1 is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2009 InternetBrands, Inc.
