Pre 84 Trucks 1st gen pickups
Carburetor problem
Old 05-12-2008, 12:46 PM
josh81sr5's Avatar
Carburetor problem
Got a question for anyone that can help. My 81 22r pickup wont stay running, just had the carburetor rebuilt as a result of this yet the problem still exists. The truck runs fine in cold weather, but as soon as the outside temperature reaches 65 or warmer it wont idle on its own. I have to hold the gas pedal to keep it running. Im not very familiar with carburetors or their components, so any help would be very helpful. Where do I start?
Old 05-12-2008, 04:33 PM
slacker's Avatar
sounds like a vaccum leak .. check your vac hoses .
or maybe , take it to the people whom rebuilt your carb .. might be a gasket issue .
Old 05-12-2008, 08:00 PM
84sr5yoty's Avatar
Isn't there an idle solenoid of some sort that goes bad and causes this problem? I'm EFI so I don't have or know the specifics.
Old 05-14-2008, 12:06 PM
josh81sr5's Avatar
All my vaccum lines are correct according to the diagram I printed out, would the choke have anything to do with this problem?
Old 05-14-2008, 12:08 PM
TOYOTA 1's Avatar
did you ever reset your idle??
Old 05-14-2008, 12:30 PM
Sked's Avatar
Pull out a voltmeter and check if your choke is getting any power? I had that problem before so i wired my choke to the fuel-cut wire. Maybe setup your choke again, not very hard just loosen 3 screws and rotate.
Old 05-14-2008, 02:00 PM
josh81sr5's Avatar
Believe my buddy that rebuilt the carb did, it ran fine for a day or so before it developed the problem. I know he adjusted the idle, as far as the choke dont know.
Old 05-14-2008, 02:03 PM
josh81sr5's Avatar
how would I identify the fuel cut wire to try that?
Old 05-14-2008, 03:40 PM
Sked's Avatar
There should be 2 wires coming off your carb, one for choke and other is fuel-cut. The wire that goes more to the top of the carb is the choke. Just unplug the green connector and test out the terminals. Should only be getting power when the ignition is ON.
Old 05-14-2008, 08:45 PM
rowdy235's Avatar
does it still not idle when its warm? Mine didn't idle at all when I bought it, Engine fuse was blown. Something to look at before you go tearing into it.
kazuya2416
04-05-2024 02:17 AM
theking11863
03-19-2016 09:36 PM
Jonny246
07-24-2015 12:37 PM
luckypig44
07-19-2015 11:25 AM
kyletbert
07-17-2015 11:39 AM
Quick Reply: Carburetor problem
