22R oil pump question
I am in the process of redoing my timing chain on my 81 22r, every thing is going pretty straight forward with the help of other posts and the search function. but for the life of me i cant find any info on the gears inside the oil pump. and where the arrows are suppose to line up to when re assembling
my question is, "where do the 2 arrows(facing away from crankshaft) on the oil pump gears line up with?"
I can post pictures if it would help.
as far as the bolt I mentioned ...
the top bolt on the oil pump .. is a "threw bolt" as seen in this pic
if the wrong bolt is installed .. it will contact the tensioner and interfere with it's performance ..
make sure you put the correct bolt back in this place ..
09-04-2015 09:27 AM
TURBOrunnerNM
07-22-2015 11:01 AM
