22r crank size
22r crank size
Okay so I am rebuilding a motor and I'm trying to find what size bearings I have or if I could just measure the crank journals with a dial caliper. Does any one know what the stock size of the crank journals are?
The bearings have a sign like (lh) and say H30S
0170A
Please help
0170A
Please help
well its just getting a basic rebuild and the bearings in it still had easily had under 50k on them I am fairly sure the motor has be gone through before be I just wanted to be sure. Plus the crank is in perfect condition not even the slightest scratch.
Plasigauge won't tell you if you have an out of round oblonged journals. I highly suggest you have a machine shop look at both the crank and the block.
Why are you tearing apart the motor after only 50k?
Well the motor was a junkyard motor and I wanted to tear it apart to be sure it was good. Also I took dial calipers to it all the way around each journal and the measurement didn't change.
I found the measurements of the standard journals and I was with in thousands of the standard
Never mind I measured bearing thickness, journals, bore and they're all STD and all with in round. Now I just need a speedy sleeve on the rear end of the crank
justdifferentials
Just Differentials
08-15-2015 05:25 PM
coffey50
07-28-2015 10:55 AM
