Tool Time Discussions here pertain to the use of tools you use while fabbing and wrenching in the garage
Yota ... Required Tool List
Old 02-23-2009, 11:51 AM
  #41
youngbuck's Avatar
You need a 10mm hex for front diff drain plug and No.1 Idler Pulley.
Old 02-23-2009, 12:07 PM
  #42
littlecommando's Avatar
Originally Posted by DC Hoerunner
Don't forget bailing wire for when you lost a bolt and need to hold up your brake lines till you get to the hardware store. or to hold things to gether that break on the trail(like when the battery strap breaks and the battery starts rubbing on the pully)
or, just make sure there is another car there whenever you work on it, that is safer
im surprised no one has said spark plug sockets yet
a magnet on a stick thing for getting bolts you dropped out of the engine compartment is useful
trays to hold stuff when you take it out
Old 02-23-2009, 01:18 PM
  #43
Windsor's Avatar
I came across something that required a 21mm wrench/socket, also. xfer case fill plug, I believe.
So that makes 8mm-17,19,21,24mm for socket and wrench.
Old 02-23-2009, 01:42 PM
  #44
hross14's Avatar
ME--
**Swivle sockets in both 1/4 and 3/8--get them as small and as large as possible.
**LARGE continious extension in all sizes--when you are using the impact to many extensions make for to much play.
**OTC front end pullers/Kit--stay away from pickle forks--they "fork" up stuff--
**Torque wrench in Inch Lbs and Foot
**Good circuit tester
**Test Light--a good one
**Lots of various jumper wires and clips
**Soldering Gun
Old 03-01-2009, 08:30 AM
  #45
Banned 'cause I was 4runnerchevy also banned
86toylet's Avatar
Required, when working on a Yota
Old 03-05-2009, 10:09 AM
  #46
fatoldcapt's Avatar
Toyota Tool Bag
Something I'll share with you that I find works quite well are tool bags. Those cheap little bags like you find at harbor freight or the surplus store. I use 6 of them set up with Metric Wrenches in one, Metric Sockets, SAE Wrenches, SAE Sockets, Misc Tools (pliers, screwdrivers, allen wrenches, short handle hammer, etc) and Electrical (switches, fuses, wire, connectors, crimpers, stripers, side cutters, etc.) These can fit behind the seat or on the passenger floor. If I need something, I grab the bag I need without having to dig through a clunky tool box. I don't have to load and unload a 40 Lb tool box. And the tools don't rattle on the trail. (Most of the time I carry the tool bags in an in the bed storage box that locks). I carry extra fluids, water, BFH (hammer) shovel, tow strap etc. Works pretty well for me and my little truck.
Aaron
Old 03-05-2009, 11:43 AM
  #47
kdx2000's Avatar
A set of acetlyene torches!
Old 03-05-2009, 12:17 PM
  #48
Windsor's Avatar
Your first post. welcome.
That is a good idea, I've been meaning to pick up some of those.
Old 03-05-2009, 06:13 PM
  #49
86toylet's Avatar
I like the idea of cute little tool bags. I have a few tool bags myself, but I keep them in a truck box, thats bolted down, and has a lid. This keeps little tool bags from hitting me or my passeger, in a rollover!
Blamalam
03-12-2022 07:34 AM
dumpster84
04-30-2016 06:03 AM
justdifferentials
Just Differentials
08-15-2015 05:25 PM
priest16
15
08-06-2015 07:43 AM
Quick Reply: Yota ... Required Tool List
