Tool Time Discussions here pertain to the use of tools you use while fabbing and wrenching in the garage
Any one know what this tool is called, or where i can buy one?
Old 03-12-2015, 10:33 AM
DHWRIGHT's Avatar
Old 03-12-2015, 11:05 AM
millball's Avatar
Looks like a bearing separator.
Can be bought at any tool supply place.
Prices can vary widely, so shop around.
It is my experience that most cheap tools are worthless, and they often do more damage than good.
Good brand name tools are forever.
Old 03-12-2015, 11:13 AM
DHWRIGHT's Avatar
Ok thanks, I have had it for years and it finally broke. this one was Mac tool but they don't come by my work any more and the Matco truck wont come for another week needed it this weekend and now I know what its called I can call around.
Old 03-12-2015, 11:37 AM
JasonYota's Avatar
What did you use it for if you didn't know it was a bearing separator/puller??
Old 03-12-2015, 12:15 PM
DHWRIGHT's Avatar
I work at a Yamaha dealership and I use it rebuilding superchargers. bolt the flat side loosely around the back of the impeller shaft so the splined part can hang out the bottom of the press plate and support the bearing journal. Impeller shaft has needle bearing with clips holding it in so never requires much force but takes pressure off the aluminum housing. Also to remove gears off main shafts on some motorcycles. worked great for years till I actually needed it installing my 5.29s and locker. I was calling it a sprocket puller and every one looking at me stupid, but for 4 years working here that's what every one called it lol.
Old 03-12-2015, 12:35 PM
DHWRIGHT's Avatar
Now it make perfect sense why when I bought it came with a bearing puller. Have to cut me some slack because I came to work here straight after MMI and I was young and impressionable and the Mac man offered it to me saying that's what the other guy used. think I will buy a cheap one from harbor freight to use over the weekend and replace the broke one with Matco's version next week.
oldirtydirt
02-23-2020 09:30 AM
jasonty
41
12-23-2018 01:00 PM
justdifferentials
Just Differentials
08-15-2015 05:25 PM
58rennur4
08-04-2015 08:49 AM
skoti89
07-08-2015 12:05 AM
Quick Reply: Any one know what this tool is called, or where i can buy one?
