Power steering stuff
I am converting my 22re pickup to power steering, I have the pump and pump bracket, what I am looking for is the reservoir, the tensioner pulley and bracket that bolts to the pump bracket and the pulley that drives the power steering that bolts to the crank pulley with 4 bolts.
Update: Thanks to everyone here but it looks like I have it all now.
"the tensioner pulley and bracket that bolts to the pump bracket and the pulley that drives the power steering that bolts to the crank pulley with 4 bolts." dont exactly know what you mean by that, try and be a little more specific, i can check my yard, hes cheap for my stuff!
The tensioner for the belt for the power steering and the bracket that it bolts to, it is circled in yellow and is red in this pic, I have the bracket that holds the Power steering pump which is black in this pic and bolts to the block.
And the Crank pulley or harmonic balancer, whatever you want to call it, should have room to drive three accessory belts for alternator, A/C and Power steering, mine has 2 and the very outside part of the pulley is what drives the Power steering, it is held on by 4 bolts and is separate from the part that drives the alternator and A/C.
montanatruck
02-26-2017 07:07 AM
terminator
07-27-2015 07:13 PM
whereAreMyPants
07-22-2015 03:32 AM
jon.r
07-11-2015 03:34 PM
