Help! I've got an oil leak!
Old Nov 9, 2006 | 04:18 AM
Maverick's Avatar
My Yota has a slow oil leak. Any ideas as to the cause? How do I find where? Thanks.
Old Nov 9, 2006 | 05:41 AM
gohawks's Avatar
Where is the oil puddling? Valve cover gaskets, rear main seal, are good bets. Everyone probably needs a bit more information to help.
Old Nov 9, 2006 | 07:47 AM
Elton's Avatar
oil filter ?
Old Nov 9, 2006 | 07:48 AM
04 Rocko Taco's Avatar
engine? and location of where you see the oil? pics are helpful.
Old Nov 9, 2006 | 08:05 AM
itsmeagain5789's Avatar
degrease the hell out of it and see were it leaks
Old Nov 9, 2006 | 08:25 AM
x 2.
Run your engine up to operating temp, and soak it down in degreaser and let it sit about 10-15 mins and hose it off, and see where you see oil first over the next couple of days.
Old Nov 21, 2006 | 04:44 AM
Maverick's Avatar
Cool thanks I'll try that.
Old Nov 21, 2006 | 04:53 AM
91TPU's Avatar
if your truck is so equipped with one, check your oil cooler...looks to me like that seems to be a pretty frequent area where we get leaks. this all depending on if your engine is a 3vze or not, that i was just assuming.
Old Nov 21, 2006 | 01:34 PM
Ghostpilot's Avatar
Mine were valve cover gaskets, leaking down the back of the engine
Old Nov 21, 2006 | 03:10 PM
SwampThing's Avatar
My oil leaks were from the two most hated parts... Timing cover gasket, and oil pan gasket. Definitely a PITA.
Old Nov 21, 2006 | 03:15 PM
highway's Avatar
my leak was underneath and i degreased everything and found out the oil drain plug has a slight leak and blowing back, guess my next oil change i will install a new one
highway
Eggslinger
Jun 8, 2019 03:32 PM
Ladythump
22
Nov 9, 2015 08:53 AM
jakebarrett
Jul 10, 2015 07:15 PM
Coreyr384
Jul 10, 2015 11:13 AM
87blyota
Jul 10, 2015 04:31 AM
